Exa Pump Users, Have Questions.
Old Dec 13, 2010 | 06:28 PM
TT Z06's Avatar
TT Z06
Default Exa Pump Users, Have Questions.
What drain size hose are you using from turbo to pump.
What is the hose material? IE: Stainless braided line?
How is your pump wired to run?
Old Dec 13, 2010 | 08:03 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I know I already told you I am using -10AN from each turbo.
SS braided line
It's wired through a relay from the fuel pump wire under the underhood fuse box.
Old Dec 13, 2010 | 08:35 PM
TT Z06's Avatar
TT Z06
yea I found a old post by you that broke it down as well. I looked at some sts turbos and it appears as they has -8 coming from the turbos. I know -10 is better but it would greatly help my ability to route it if I can use 8 with no adverse affects. Also need to mock it up for short term use with hydraulic hose until the final measurements are made. then I will upgrade it to SS lines.
To Exa Pump Users, Have Questions.
