Rocker Arms
Old Dec 16, 2010 | 12:37 AM
denscor's Avatar
denscor
Default Rocker Arms
I was having a light tick coming from my LS7 on the right side. I took off the rocker arms and discovered that on of the rocker arms the needle pins were missing. Should I get the rocker arms repaired or just buy the yella terra rocker arms. I am also planning on changing the cam to .650 lift plus I run 16-18 pounds of boost. I'm afraid that the new springs I will be running are that rated up to .700 lift will put a lot of pressure on the rocker arms. I have also heard that the Yella Terra rocker arms are too heavy for the valve system on a LS7.Thanks
Old Dec 16, 2010 | 09:02 AM
Milan's Avatar
Milan
I'm running the yella terras, personally I would never go back to the stock setup
Old Dec 16, 2010 | 09:09 AM
jobberone's Avatar
jobberone
jobberone
Why do you want to run so much lift with that much boost?
Old Dec 16, 2010 | 01:24 PM
robert miller's Avatar
robert miller
Would replace all of them just for piece of mind. Stock rockers look to be good up to about 650 lift. After that would look at a good aftermarket set up....
Old Dec 16, 2010 | 02:36 PM
denscor's Avatar
denscor
I have a F1 and it has the biggest pulley that I can run to keep the boost down.
Old Dec 16, 2010 | 03:03 PM
marco383's Avatar
marco383
It's interesting that you're getting 16 psi plus with the largest F1 pulley on a 427. I'm running LS7 heads on a built 427 with an F1C, and the big pulley only nets me 8 psi.
Old Dec 16, 2010 | 03:10 PM
denscor's Avatar
denscor
It maxed out the boost gauge and its rated to 15lb, plus the dyno showed it. Trust me my tuner does not like that much boost with a LS7. The motor was build by Texas Speed and Performance all forged.
Old Dec 16, 2010 | 05:47 PM
robert miller
I am with you the biggest pulley and running 16to18 lb of boost something is wrong with your gauge. I dont see anyway. On the 427 bigger ci mean lower boost #...
Old Dec 16, 2010 | 06:15 PM
denscor's Avatar
denscor
The dyno and the hp tuners showed it also. I have the older bigger intercooler. And when I had a 3.75 pulley on it I had 14lb of boost at 3500rpms.Maybe something is wrong with the other 427! I have the dyno sheets and data showing its at 16-18lbs. aske Dale from tack it up motorsports and Bluecat Tuning.
Old Dec 16, 2010 | 10:45 PM
robert miller
Denny, from others on here and on that big of pulley just dont see that much boost of 18lbs.. Not saying or mean at all that you wasnt telling what was told to you. Maybe some other here will chime in that have 427 set up,s.....
Old Dec 16, 2010 | 10:53 PM
denscor's Avatar
denscor
I was there during all dyno pulls. I mean hey I was only wanting around 10 lbs of boost. But the pulley is a 4.7 and anything bigger hits the brackets. i have a 4 inch and a 3.7 inch pulley and never have used them.The rocker arms are bad so I going to replace them. I have read that this is normal with the LS7 because they are offset and bigger springs stress them. Just wanting to know what is better way to go, fix old ones or buy yella terra.
Old Dec 17, 2010 | 01:38 PM
rwisk's Avatar
rwisk
comp cams makes a replacement trunion kit.I run a ls1 and replaced all mine
Old Dec 17, 2010 | 02:23 PM
Neil B's Avatar
Neil B
I agree. I only get 15psi with my F1R using a 4.13 pulley on 404ci.
Old Dec 17, 2010 | 04:39 PM
denscor's Avatar
denscor
went down today and checked boost gauge and its right on the nose. So it must be right.
Old Dec 20, 2010 | 10:06 AM
robert miller
Denny, that is good on the pulleys and the boost. But yes I would get the yella terra rockers for sure. Glad the car is running like it is on the boost. I like the F1 AND F2 units wise I had one now.
Old Dec 20, 2010 | 10:37 AM
HIGHRPM's Avatar
HIGHRPM
How did you check the boost gauge? I'm running a 3.75" pulley on a 429 and getting 14 psi with an F1R..... your boost readings seem off......just doesn't make sense with an F1. Your just not spinning the F1 hard enough to make 18 psi.
Old Dec 20, 2010 | 11:06 AM
HIGHRPM's Avatar
HIGHRPM
That sounds just right.....when I ran a 4.10" I got 11 psi.
To Rocker Arms
Old Dec 20, 2010 | 02:08 PM
denscor's Avatar
denscor
The old fashion way, took a old valve used some fittings.Took manual tire pump put gauge at 15psi and the checked it with tie gauge. tire gauge was at 15psi.I used to check my other cars that way and the were correct.
Old Dec 20, 2010 | 04:14 PM
HIGHRPM's Avatar
HIGHRPM
Still, that doesn't account for the fact that your not spinning the F1 fast enough to make 18 psi...... its just not physically possible. Your running a pulley that's over 20% smaller and your saying it somehow makes over 20% more boost than a 3.75" pulley on the same size motor. What rwhp/rwtq numbers are you seeing. Please post the dyno chart that shows boost levels vs power levels.
Old Dec 20, 2010 | 05:53 PM
Vettedriver986's Avatar
Vettedriver986
i just installed comp cams needle bearing replacements in my stock rockers. Seem to be a lot more sold now. rids of the needle bearins and replaces them with solid bearings. theyre nice.
