Procharger life expectancy?
Old Apr 7, 2002 | 11:33 PM
MelloYellow's Avatar
MelloYellow
Default Procharger life expectancy?
How many miles should I expect out of a D1-SC before I need the supercharger rebuilt?
Anyone have experience with supercharger rebuilds, cost & turn around time?
Thx!
Old Apr 8, 2002 | 11:20 AM
Cya5's Avatar
Cya5
Default Re: Procharger life expectancy? (MelloYellow)
That all depends on how fast you spin the blower.
Old Apr 8, 2002 | 12:13 PM
MelloYellow
Default Re: Procharger life expectancy? (Cya5)
Not sure what size the pulley will be, but am looking for 8-10psi.
On a Camaro, that's probably a 3.20" pulley.
Old Apr 8, 2002 | 01:07 PM
dbvettez06's Avatar
dbvettez06
Tough question..Maybe a call to ATI might help :confused:
Old Apr 8, 2002 | 01:56 PM
MelloYellow
Default Re: Procharger life expectancy? (dbvettez06)
Will do when I have some time.
Anyone with prior blower experience over the years?
Someone has said rebuild once a year or 12000 miles were common with the oil tapped units. Not sure how much a rebuild costs.
Old Apr 8, 2002 | 02:17 PM
MelloYellow
Talked to ATI.
They seemed to feel ok with 100k miles, w/6k oil changes.
Most rebuilds are cheap. Watch for oil leaks. Metal on magnet plug. Don't overfill the oil.
Full failure replacement of the compressor would be around $2600 in a worst case scenario.
Old Apr 8, 2002 | 03:35 PM
dbvettez06's Avatar
dbvettez06
I wonder what kind of oil they use in the self-contained ones, p1sc etc???
Old Apr 8, 2002 | 05:05 PM
MelloYellow
Some kinda special 6000 mile Synthetic.
Old Apr 8, 2002 | 05:24 PM
urslooow's Avatar
urslooow
Asked Ernie from Breathless this question when I saw your post earlier today, he was very circumspect about it. It reeally depends on how much you pound on it. Ernie reccommends changing SC oil every 3000 miles, I read what ATI said (6000).
Old Apr 8, 2002 | 06:59 PM
MelloYellow
Default Re: Procharger life expectancy? (urslooow)
3000 makes sense.
100k before a rebuild sounds like a long time to me.
Guess you just keep an eye/ear on it.
Old Apr 8, 2002 | 07:50 PM
Jbrady's Avatar
Jbrady
Look, I like centrifugal superchargers but 100k miles? Please. I would like to hear from ANYONE that has 50k on an un-rebuilt head unit. I would suggest the average time between rebuilds is more like 20k.
These things have some high internal loads to deal with.
Old Apr 9, 2002 | 12:13 AM
jeff_nation's Avatar
jeff_nation
Default Re: Procharger life expectancy? (Jbrady)
I will be happy to answer that question. Let me put a few hundred hard miles on my D1-SC.
-Jeff Nation
Old Apr 9, 2002 | 10:04 AM
MelloYellow
That's what I was thinking. ATI didn't want me to send it in every 20k tho. They said, just watch for metal in the oil or oil leaks. Hmm...
Old Apr 9, 2002 | 10:32 AM
dbvettez06's Avatar
dbvettez06
Still wondering what type of oil is used in the unit :confused:
Old Apr 9, 2002 | 03:13 PM
molon labe's Avatar
molon labe
Default Re: Procharger life expectancy? (jeff_nation)
-Jeff Nation
OMFG. your car is sick and you disgust me.
you have the exact car and mods i want. :)
please keep us updated on your car.
Old Apr 9, 2002 | 07:52 PM
Jbrady's Avatar
Jbrady
Default Re: Procharger life expectancy? (tattooed)
Jeff_nation,
That is one bad butt Z06. I hope you did not take my post as an insult in any way.
The internal loads that I refer are due to the step up gearing and the way the blower is operated. You have a LARGE gear driving a SMALL gear. This creates LOTS of load. The compressor is moving large quantities of air and that air has weight. Every change in RPM, both up AND down, creates shearing loads, inertia loads and aero drag loads. If a setup does not have a compressor bypass valve the surge further exasperates the issue. Cruise charge temps are also raised considerably (without bypass) as the blower makes boost (and the heat related to such) against a closed throttle plate. The intake after the throttle sees vacuum but not between the compressor outlet and throttle. Have seen some interesting tests. Turbo compressors (and attached turbines) do not experience such harse changes. Roots and Lysolm compressors are moving relatively MUCH lower RPM. (bypass is also needed in these units but for a slightly different effect).
Old Apr 9, 2002 | 08:21 PM
jeff_nation
None taken whatsoever. :)
-Jeff Nation
Old Apr 14, 2002 | 03:04 AM
VERTVETTE's Avatar
VERTVETTE
The P1SC1 comes with 5 containers of pro-charger oil. Each container is a change. so you get the fist 24500 miles worth of oil changes with the kit. ATI recommends 500 miles on the first change and 6000 every additional change
To Procharger life expectancy?
