I just installed a fuel pressure gauge on my '00 and it's readings have me confused. When I turn on the ignition the gauge goes right to 58lbs but when I start the engine it jumps to about 68lbs. I'm using an auto meter sending unit fed off the fuel rail with a 3' 4an line as the gauge instructions recommended not mounting the gauge directly to the fuel rail because of possible vibration issues.
I thought maybe the sending unit was bad but like I said it reads 58lbs when the ignition is turned on so I don't know what is going on.
The increase in fuel pressure when the car is running could be due to the fact that you have higher voltage, when the ignition is on the pump is just running on battery voltage, or the gauge is sensitive to the voltage change.
Nope, stays at 68 even after driving the car for a while.
Maybe it is a voltage issue, I used the A&A write up to do the install and got my power from the yellow wire under the steering column.
Another ground may give a different reading. FWIW, mine usually reads high at first, especially in cold weather. The other day I saw 71psi on startup. If you saw 21psi, then I'd be concerned.
Sorry to bump an old thread, but I am having the same issue, and I'm wondering if OP ever found a solution.
I see 58 psi key on engine off, but as soon as I fire it up it goes to 64 psi.
Could it be that the extra voltage from the racetronix harness is upping the fuel pressure? Even if that was the case what's the point of an adjustable regulator if it can't regulate a couple extra volts at the pump?
The Racetronix harness is supplying more voltage to the fuel pumps so, yes, that could be making your fuel pressure run higher than 58psi.
i have exact problem, when the key on read 58psi (12v on the volt reading) and when i start the engine jump up to 64psi. (14v on the volt reading)
and i dont know how it get power.
any solution?
If you are looking for power for the fuel pump/guage, trace the positive wire from the pump/guage. As stated above, when boost referencing, leave the vaccum/boost line off your FPR at idle.
For reference, my car, boost referenced, is at 58 psi at startup. When at WOT I hit 68 psi.
Put a mechanical guage at the FPR to get a more accurate reading. My guage reads a little higher in car for whatever reason.
I am running an a and a fuel system, hence the FPR. If you don't have one, put guage coming off the fuel rail.
