Which Fuel pump?
Old Jan 7, 2011 | 02:21 PM
PhilsZ51's Avatar
PhilsZ51
Default Which Fuel pump?
I have decided to go down to one external fuel pump, don't really see the need for two. Which
pump do you guys recommend? I have 2 bosch 44s right now, but one of them is on its way
out and I figured I would just buy a brand new pump. Should I stick with 1 New 044, or should
I look into a different pump? I have one 255 in the tank right now and I am looking for the
850hp range. Thanks.
Old Jan 7, 2011 | 02:25 PM
Milan's Avatar
Milan
You should look at that new Aeromotive in tank..its the same size as a walbro 255 only flows 340 lph, 404 lph @ 17 volts
Old Jan 7, 2011 | 02:32 PM
PhilsZ51's Avatar
PhilsZ51
I was thinking of an in-tank setup but I have already drilled the tank, and ran all of the lines for the way it is setup right now.
golfinz's Avatar
golfinz
I have a stock intank and an 044 external and should see mid 700s-800rw. I would do my setup but with the new aeromotive 340 pump instead of the 044. Or swap the 044 with the a1000
Slow Z06's Avatar
Slow Z06
A1000
Old Jan 7, 2011 | 02:33 PM
golfinz's Avatar
golfinz
Originally Posted by Slow Z06
A1000
Old Jan 7, 2011 | 02:36 PM
PhilsZ51's Avatar
PhilsZ51
I have read a little about the new 340, but it hasn't been released yet, has it? I used to have an A1000 on my TT cobra and that thing was a bit on the loud side.
Old Jan 7, 2011 | 02:47 PM
dsmlights's Avatar
dsmlights
1 intank and 1 bosch in parallel should do the trick for 850 ???
if not look at this bad boy
http://www.weldonracing.com/product/...Fuel_Pump.html
golfinz's Avatar
golfinz
The new aeromotive 340 is supposed to be out at the end of the month but jegs says it will be available to ship on 3/11/11 I believe. There is a thread about the 340 in the C6 FI section if you want to check it out.
Old Jan 7, 2011 | 02:51 PM
PhilsZ51's Avatar
PhilsZ51
I am hoping that it will. I did over 550 with just the 255 in the tank, no BAP. I am hoping the additional pump will make up the difference.
Old Jan 7, 2011 | 03:10 PM
venomws7's Avatar
venomws7
I'm going to try RSI hanger with twin 255 1st if its not enough I'm going with either the Magnafuel 4031 or 044 Bosch.
Old Jan 7, 2011 | 03:22 PM
PhilsZ51's Avatar
PhilsZ51
I like the Magnafuel mp-4301 or 4302.
Old Jan 7, 2011 | 03:29 PM
Slow Z06's Avatar
Slow Z06
4 A1000's in series
seriously though, the A1000 might be a lil on the loud side, use it off a hobbs switch to only come on under boost. Youll never notice it.
Old Jan 7, 2011 | 03:34 PM
PhilsZ51's Avatar
PhilsZ51
That is how it is rigged now(hob switch). I see that the A1000 has -10 inlet and outlet; I am assuming they make a reducer from -10 to -8 so it will fit my feed line?
Old Jan 7, 2011 | 03:41 PM
Slow Z06's Avatar
Slow Z06
You could reduce to an 8, or upgrade your lines to a 10
Old Jan 7, 2011 | 03:48 PM
IPS Motorsports's Avatar
IPS Motorsports
How about fuel labs? http://fuelab.com/products/prodigy-fuel-pumps
There have really nice brush less motor set ups!
Other wise stick with the 044
Regards
Old Jan 7, 2011 | 03:59 PM
PhilsZ51's Avatar
PhilsZ51
I am kind of leaning towards the Bosch 044 now, just because that is what I was using. I need to find a check valve for the pump though. Jayracing seems to be the only place I can find one, and they are out of stock.
To Which Fuel pump?
Old Jan 7, 2011 | 06:34 PM
95vettski's Avatar
95vettski
I'm using the Magnafuel 4303 on my set up
Old Jan 7, 2011 | 06:43 PM
golfinz's Avatar
golfinz
I think I remember reading somewhere that the 044s have an internal check valve....might be wrong though
Old Jan 7, 2011 | 08:19 PM
Z06supercharged's Avatar
Z06supercharged
The 044 pump in the kit I have from A&A has a check valve on the pump outlet so probably doesn't have a internal one.
