nitrous
Old Jan 11, 2011 | 12:21 AM
Badd LS6's Avatar
Badd LS6
Default nitrous
hey all...i just picked up a NX kit for my 04z06
and was just curious to how the line was ran from the trunk to the engine bay..also do i have to change out my injectors for spray? im gonna be swappin my plugs for cooler ones. i plan on starting off with a 75 than eventually a 125,no higher than that.
Mods are:
longtubes
catless X.
borla straight pipes
vararam
UNTUNED
385rwhp 378tq
was also wondering what kinda numbers ill be putting down. does anyone have similiar mods with a shot. what kinda numbers your putting down and 1/4 mile times with how big of a shot
Old Jan 11, 2011 | 06:15 AM
Beer99C5's Avatar
Beer99C5
Junior Member
St. Jude Donor '08
Most run the line down the passenger side and thru the gromment in the firewall located beneth the battery.
I used this for most of my install
http://www.hotrod.com/howto/3447_che...all/index.html
If its a wet kit you should not have to upgrade the injectors. If its a dry kit you may want to consider upgrading the injectors (your probably OK but each car may be a bit different based on the installation or kit).
Old Jan 11, 2011 | 07:59 AM
ZO6ME's Avatar
ZO6ME
I was running 427 rwhp without nitrous and my stock injector cycle was at 98%. With a 100 shot I had a good chance of running lean. I have a set of 36 lbs Bosch injectors that have only seen dyno time. pm me if your interested.
Old Jan 11, 2011 | 09:22 AM
Sea Five's Avatar
Sea Five
once the battery is removed you have tons of room to snake wiring or the nitrous feed line through the firewall. might as well throw your relay / window switch in the battery area, as its right there and easy to work with. run your feed line under the door kick panel moulding, and into the trunk.
Old Jan 11, 2011 | 09:37 AM
Badd LS6's Avatar
Badd LS6
sounds very simple. time to get to work
thanks guys!!!
Old Jan 11, 2011 | 09:53 AM
robert21122's Avatar
robert21122
i know on my c5 it will handle a 125 dry but anything over have to change injectors and you can run 150 wet i have heard people running 200 but i stick with 150
Old Jan 11, 2011 | 10:14 AM
Badd LS6's Avatar
Badd LS6
i will be running a wet kit
Old Jan 11, 2011 | 10:38 AM
robert21122
well then it can take 150 i would get all the safety switchs like the fjo progressive controller which has the rpm window and wot switch built in
Old Jan 11, 2011 | 01:22 PM
Badd LS6's Avatar
Badd LS6
i have a NX window switch and according the manual it has a WOT switch built in as well..i gotta have the install shop clarify it..i have a fpss as well
Old Jan 11, 2011 | 04:53 PM
SargeZ06's Avatar
SargeZ06
I'm running NX Wet kit. I was running a 150 shot but moved to an undisclosed number currently.
I have SVO 30# injectors and the duty cycle is around 70%. I also run a KB Boost-a-pump to increase fuel pressure are WOT.
I'm 467 NA and no idea what is is with the 150 shot. I guess 150 over that.
Here is a link to my install over on ls1tech.com
C5 Z06 NX 150 Wet kit install
To nitrous
