Crankcase Ventilation
Old Jan 12, 2011 | 05:38 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Crankcase Ventilation
Hey guys, I put a Moroso breather can on the car and today was the first day I drove it since the new additions since Thanksgiving.
I drove it today for ~50 miles and came home to change the oil. I noticed just a little fluid in the can, so I emptied it. To my surprise, it was just water. Maybe from condensation?? Anyone ever experience this?
Also, I noticed at idle, there is a little bit of smoke constantly coming from the breather on the can. Is that normal??
Old Jan 12, 2011 | 06:05 PM
Slow Z06's Avatar
Slow Z06
could just be cold vapor you are seeing. Are you running check valves in you setup or open both ways?
Old Jan 12, 2011 | 06:08 PM
Corvette-Chris
St. Jude Donor '08
Yeah, I figured its some kind of vapor, but wanted to see what everyone thought.
Its a 1-way can. A -10AN line from each valve cover that "T's" into a single -10AN into the can. No checkvalve
Old Jan 12, 2011 | 06:47 PM
Chris Stewart's Avatar
Chris Stewart
Bust out the pics already yo!
Old Jan 12, 2011 | 06:56 PM
Corvette-Chris
St. Jude Donor '08
Here go da pic
You cant see the line coming around behind the engine from the drivers side cover, but you can see the passenger cover line and the can.
Old Jan 12, 2011 | 07:40 PM
leo12's Avatar
leo12
dont worry man its just vapor, thats a good thing
Old Jan 12, 2011 | 07:47 PM
Milan's Avatar
Milan
Chris how big are those nozzles on your meth kit?
Old Jan 12, 2011 | 09:02 PM
Corvette-Chris
St. Jude Donor '08
Man, im not too sure. I installed the kit and let Taylor pick the nozzles when he did the tuning. Haven't touched them since.
Old Jan 12, 2011 | 10:51 PM
Scubanme's Avatar
Scubanme
A little bit of constant blow by is normal out of the breather.
Old Jan 13, 2011 | 11:35 AM
corvettebob1's Avatar
corvettebob1
How do you keep from boosting the crankcase W/O a check valve?
Old Jan 13, 2011 | 11:47 AM
Corvette-Chris
St. Jude Donor '08
It's the same concept as if I had a breather on each valve cover, except I am using lines into a can. There is no line back into the motor.
Old Jan 13, 2011 | 12:35 PM
Milan's Avatar
Milan
^ that's how we did it in the import world too
To Crankcase Ventilation
