Just put an A&A fuel system in it and got it re-tuned. It made 550 tq @ 5300 and 620rwhp @ 6500. Now here's the kicker. At 54k the afr hit 12.74, lost about 20hp and 30 lbft tq, and at 55k a crap ton of fuel hit and the afr went to 10.4, needless to say hp/tq rose up again. This was at 7.5 lbs of boost. It was a gradual leaning out of fuel, not a spike or anything. Gonna check the hobbs switch with a mityvac tomorrow but if that is working fine then it would be a FML situation. Mainly because I wouldn't know what to do. If the switch is jacked ill call up Mr.Steve or Mr.Andy and get me a switch. By the end of the pull it got 10.4 lbs of boost. Anyone else see that much boost with a stock ls6 motor, L/Ts. V3Si and 3.8 pulley?
Those Hobbs switches are very reliable. Do you still have stock valve springs? Sounds like you might have a possible valve spring issue. That's the RPM where the power seems to dive when you have weak springs. Higher than average boost can be a red light to a restriction problem such as catalytic converters. Post up a dyno sheet if you have one.
Thanks for the help. Got questions. Is there a reason why the springs at that rpm get weak and then at an even higher rpm they seem ok? And I'm not planning on changing the cam at all just going to build a forged 346 later on but what should I get for valve springs?
It made really good power up top. And it only had one dip in the graph and the AFR went fat and dropped power for 400 rpm then picked back up to 620. Maybe the maf got maxed and the tune was bad for a bit. Or maybe the hobs is screwing up? Thought the graph would be chopping up top along with the boost with bad springs. No expert though.
I did road test the pump. Fuel pressure steadily increased as the boost increased but I didn't hear the pump come on, only went to 5 psi. Not gonna play around with it to much. Thank you for your input. Im going to order the patriot golds and schedule a tune at a different shop. Probably one that is a vendor of A&A. Might be a few weeks before I get results back but Ill revive this thread and let you all know what was going on. About the springs screwing up only for a little bit, no clue. But I consider the members that responded to be experts so Ill take their word for it. If it turns out to be wrong, hey, ill have nice springs
I have a procharger with a 3.7, so it's apples and oranges, but I'm a little over 10psi.
The high boost is because your engine is not as efficient as it would with better heads and cam.
I'll be in the minority here, but I wouldn't think of pushing my stock block to 6500 with that kind of power. I limit mine to 6150-6200 max.
I think it is a tune as well. It eases up to 12+ then back down. That may be where the MAF runs out, and the tune needs tweaking.
I'm not expert enough to go against the majority saying it's the springs but to me it sounds like a tune problem.
Could very well be. Need to look at the tune and logs to know.
Could also be from trying to run through 1/2 clogged cats. That will cause eleveated boost, but the car should nose over on power up top from it.
Originally Posted by Chris Stewart
FWIW, I have stock springs and it pulls strong thru 6400 RPM.
Seems to be hit or miss with springs on these cars. I dunno.
Yeah I've seen posts from guys that broke a spring just pulling outta the driveway.
Originally Posted by Milan
Damn 10:1 AFR? That's freaking rich...have you thought of leaning it up a bit and pulling a degree of timing?
Not really, I know I'm pushing it and don't wanna pop the motor. What's funny is that it's street tuned with a wideband. On the road it runs about 1pt leaner, depending on conditions. If I tune for the dyno, it might be too lean at the track.
Just for comparison, mine made 10.95 psi max from around 6500 rpm up to 6800 rpm. Same set up as you: bonestock LS6, V3-Si Trim. I honestly didn't think that head unit would make that much boost? Dyno sheet is in my profile, for what it's worth.
