Research before going FI
Old Mar 13, 2011 | 11:24 AM
Smoove's Avatar
Smoove
Originally Posted by venomws7
ZYBROG don't call this guy he doesnt know s**t
Give him a call for sure he will help you out and maybe he can give you ride in his beast..
Your such a bastagewhore.
Originally Posted by ZYBORG
Thanks for the tips, advice and opinions.
Jamie, I will be hitting you up as soon as I take care of some things...
Cool man,..looking forward to it. Going to Sebring to watch some road racing all next week so,..if it happens to be then, i'll go ahead and pre apologize if I miss your call. I'll be back the following monday though. Talk to you soon bro.
-Jamie
Old Mar 13, 2011 | 01:14 PM
Z06supercharged's Avatar
Z06supercharged
Originally Posted by wantbluC6
Then again, I hear the oil in a self contained unit just kinda sits there and doesnt really circulate. Thus not cooling the head unit as well. Also read that the life expectancy of the head unit is lower than externally oil fed as well. Pros and cons for each really.I think its easier to change the engine oil twice a year for fresh oil for the blower too. Sawbladz, if installed properly the chance of leaks is nill. Your reason number 2 is about as likely as your first.
I checked the oil temperature on a self contained unit once and it was 285+ degrees. No thanks! Ill stick with engine oil through it at 220 degrees.
Old Mar 13, 2011 | 02:45 PM
02HREBlue's Avatar
02HREBlue
I agree. Even synthetic motor oil is cheap and easy to change and doesn't make me change my mind enough to go to self-lube system. I would rather have fresh stuff often. I really haven't heard of many catastrophic failures.
ECS did mine and I am extremely happy. I was leery also but they are the real deal.
Old Mar 13, 2011 | 03:37 PM
Z06supercharged
I had my s/c head unit eat up the bearing races and all that crap went down the drain line into oil pan but did no harm to engine. I was always worried if something like that happened if it would go through engine and cause further damage. My magnetic drain plug caught most I guess and what it didnt ended up in the oil filter.
Old Mar 13, 2011 | 08:20 PM
Smoove's Avatar
Smoove
The units that are self contained,...can they be converted?
Old Mar 13, 2011 | 09:05 PM
Z06supercharged
I was told no when I inquired about that.
