how many are using a trans brace?
Old Jan 23, 2011 | 10:16 PM
95wht6spd's Avatar
95wht6spd
Default how many are using a trans brace?
When is this really needed? Is this needed on a steet car with street tires, or really only with hard launches (sticky tires, drag racing, etc.)?
Old Jan 23, 2011 | 10:17 PM
Slow Z06's Avatar
Slow Z06
if you "drive" the car, its beneficial. If its just a cruiser or grocery getter, then not at all.
Old Jan 23, 2011 | 11:11 PM
Vince99FRC's Avatar
Vince99FRC
I have it on my setup..
Old Jan 23, 2011 | 11:56 PM
robert miller's Avatar
robert miller
If it a auto not that bad but the stick cars really need one for sure to help it to hold both the trans and rear in line and together.
Old Jan 24, 2011 | 12:07 AM
Robert 2000's Avatar
Robert 2000
I did a trans brace when I did my clutch and Radiator. I dont know if it is really needed on the street with street tires but I plan to test it out at the track one of these days
Old Jan 24, 2011 | 10:46 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I have seen a handful of transmissions break on the street. Wheel hop being the biggest contributor. It really comes down to how hard do you drive the car, regardless of where it's done.
The problem with not going with one is if you break the diff and trans, it's most likely going to cost you over 3k to fix, where as a brace is under $400. The insurance is not worth the gamble if you "use" your car IMHO.
http://www.eastcoastsupercharging.co...rut_Brace.html
Old Jan 24, 2011 | 11:11 AM
robert miller
Just stupid not to have one on a stick car....
Old Jan 24, 2011 | 11:14 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Tranny brace is cheaper than a new tranny.
Old Jan 24, 2011 | 11:27 AM
95wht6spd's Avatar
95wht6spd
Are these easy to install, or should they be done with a clutch swap etc?
Old Jan 24, 2011 | 11:50 AM
DOUG @ ECS's Avatar
DOUG @ ECS
They are a little tough to install, not terrible, but easier with a clutch install and the rear assembly is down already. They are about three hours +- when thats all your doing, less then an hour when the trans is down already.
Old Jan 24, 2011 | 12:00 PM
Dave concrete's Avatar
Dave concrete
Cheap insurance.
Did the brace and the mount and it feels planted. Plus when you hop a bit off the line you don't clinch your *** in fear.
Old Jan 24, 2011 | 01:21 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
I have one and it's worked beautifully.
Old Jan 24, 2011 | 01:37 PM
golfinz's Avatar
golfinz
I shoulda bought one when my tranny was out
Old Jan 24, 2011 | 01:45 PM
clemsondave's Avatar
clemsondave
Call me stupid
Don't let the wheels hop and don't dead hook and I don't think it's needed. I think there is also a misconception that the brace prevents the diff from blowing up. I believe it is actually meant to keep the transmission from twisting/breaking WHEN the diff blows. So, I guess it will save you money IF the diff blows. I prefer to drive smart so the diff never blows in the first place.
Old Jan 24, 2011 | 02:02 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Originally Posted by clemsondave
Call me stupid
True, but some of us want to do the latter. Obviously you do too. The diff wants to twist off the tranny when power is applied. The top of the diff wants to separate from the tranny. The brace keeps this from happening.
I do agree with your main point. I don't expect the brace to make the diff bulletproof, especially in my case (weak '05 diff). But it should prevent this separation which should help a lot and at the very least it should save the output shaft of the tranny in the even the case fails.
Also realize that the diff brace isn't going to help much if you let wheel hop happen.
Old Jan 24, 2011 | 02:29 PM
clemsondave
I have no desire to break anything and have never pushed my car to that point. I do go to the track, but I am very cautious in my approach.
Interesting... you want to dead hook? The few times I go to the track, I spend a lot of time just talking to people, watching and learning. The consensus I hear is that the ideal launch is about 1 revolution of the tires before they hook. I'm always up for learning how other people do it though.
If you do plan on pushing it, then I agree it is a great product... especially for $400.
Old Jan 24, 2011 | 04:15 PM
5 Liter Eater
St. Jude Donor '11
I guess it depends on your definition of dead hook and mine is probably inaccurate. My idea of a dead hook is a 1.6 60'. You definitely have more experience than me. I think if you plan to track the car at all though, then it's a great idea to have one.
To how many are using a trans brace?
Old Jan 24, 2011 | 04:53 PM
robert miller
Call me stupid
I didnt mean you were stupid at all. Just saying it is stupid to hit the track in the 1/8 or 1/4 mile and really not do a good burn out and be the 1st to the other end. Now with that being said with your statement who know what the beaking point is of your rear end in the car. All is not the same here. Just in the stick cars alot more chance of doing bad damage back there.
Old Jan 26, 2011 | 10:15 PM
Steve@TunedbyFrost.com's Avatar
0Steve@TunedbyFrost.com
Former Vendor
Don't let Dave fool you guys...
He's not what I would call easy on it
His 9-second pass goes something like this... 5,000 RPMs, drop clutch in about 0.1 second and shift each gear at like 6,995 RPMs with a 7K limit.
Old Jan 26, 2011 | 10:36 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
I got one on mine. Every little bit helps!
