From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have everything you need in stock and can ship it out today. Just give us a call.
My personal experience is do not go with oversized/drilled injectors, many shops/kits go this route to save money, but I have personally seen them take out more than one engine from them.
You can use your stock balancer. You only need to change it if you are going to a compete 8 rib kit. If you do that, you are going to have to get the power steering and alternator 8 rib pulleys as well. I have the 8 rib for the alternator on my car now, send me yours and I will give you my 8 rib. Yes, Sir. Ditch the bosch and get something loud. Get the tial, and it will fit nicely on the flange that is already welded on that pipe.
If I can stay on the stock balancer and not worry about it splitting then I will. I just read on here that the stock balancer is not the best and that's why I started thinking about the innovators west.
Thanks for the offer but if you say that I can use the stock balancer then no need to switch the pulleys right now.
If you're set on using a IW pulley, just get the 10% OD 8 rib. It'll save you some money and headaches later when you decide to finish off the setup w/ 8 rib pulleys.
