Turbo Noob?
Old Jan 29, 2011 | 07:29 PM
PhilsZ51's Avatar
PhilsZ51
Default Turbo Noob?
I am wrapping up the install with the HP kit, and I had a question regarding the wastegates. When it comes to choosing the springs that go in the wastegate, do I install the same springs in each wastegate to achieve the boost I want? I don't add them together or anything like that, do I? I am wanting 12lbs of boost, so do I just put the 12lb spring setup in each wastegate, or do I put the 6lb spring in each wastegate, equaling 12? I am not going to run a boost controller at the moment. Please forgive the ignorance
Old Jan 29, 2011 | 07:36 PM
RoadRebel's Avatar
RoadRebel
12 psi springs in each gate.
Old Jan 29, 2011 | 07:41 PM
Slow Z06's Avatar
Slow Z06
12 in each. Just keep in mind that spring pressure will be the lowest amount of boost you can run, with or without a EBC. alot of guys run smaller springs and use an EBC for kill mode
Old Jan 29, 2011 | 08:01 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Bingo.
Old Jan 29, 2011 | 09:55 PM
PhilsZ51's Avatar
PhilsZ51
Thanks. Anyone have any suggestions for max psi on pump gas. Forged 390 with 10:1 compression, 6665 turbos. I was gonna put some torco in there too... To help out this weak A$% 91 octane. I was thinking 10-11.
Old Jan 29, 2011 | 10:19 PM
Slow Z06's Avatar
Slow Z06
tune it the way you are going to drive it. I would leave the torco alone personally. FWIW i run 22 psi on a forged 347. I only recommend doing what you are comfortable with, not what others do.
Old Jan 29, 2011 | 10:28 PM
PhilsZ51's Avatar
PhilsZ51
What fuel are you running with 22 psi? I really want a pump gas car. I don't want to have to depend on getting race gas all of the time. When I had the novi, even with 7psi, I would toss torco in there just to be safe. But it was tuned on straight 91, torco was added after the tune. I usually just go by what the experts say, or people who have the experience.
Old Jan 29, 2011 | 10:31 PM
golfinz's Avatar
golfinz
move to TX so you can run 93....
Old Jan 29, 2011 | 10:39 PM
Slow Z06's Avatar
Slow Z06
I run pump 93 with a meth chaser
Old Jan 29, 2011 | 10:45 PM
PhilsZ51's Avatar
PhilsZ51
I will be moving to Pensacola, FL in May(military). I think they have 93.
Old Jan 29, 2011 | 10:48 PM
PhilsZ51's Avatar
PhilsZ51
I am hoping it will make 700 on 91 with 10-11lbs.
Old Jan 30, 2011 | 04:19 PM
fsuforever's Avatar
fsuforever
Cool man,I am 30 min from you ,yes there is 93 in. Pcola,fl,its high as giraffe #-^^^,Its 3.26 a gallon right now here in Daphne,al 30. Min from you,let me. Know when you get there & we will hook up
Old Jan 31, 2011 | 11:41 PM
PhilsZ51's Avatar
PhilsZ51
Another NOOB question. I am not running a boost controller at the moment, so how do I route the vacuum lines? Do I just connect the vacuum line from the turbo to the WG, and that's it? Also, I leave the top fitting open? I have a pair of Precision WGs.
Old Feb 1, 2011 | 11:26 AM
justz06's Avatar
justz06
bro Phil you plan to run boost control at all down the road? if you do I have greedy manual one and Greedy electric older style the once got the button on your steering wheel. let me know if you need one. I got no use for this stuff.
Old Feb 1, 2011 | 12:57 PM
PhilsZ51's Avatar
PhilsZ51
Man, the button on the wheel? I rememebr that one; that is some Fast and Furious stuff. I will get back to you.
To Turbo Noob?
