Bottle heater question
Old Apr 10, 2002 | 11:34 PM
jpvette's Avatar
jpvette
Default Bottle heater question
If I'm suppose to heat the bottle between runs until the pressure is correct, my ignition switch must be on. How does that work? Between runs, I can't keep the car running or drain the battery for the 15 minutes required to heat up the bottle. Are y'all connecting the heater differently than me? or what?
Old Apr 11, 2002 | 03:30 AM
C5Cemo's Avatar
C5Cemo
Default Re: Bottle heater question (jpvette)
I can get the bottle up to pressure on the way to the track and it won't fall off that far if it's full. I do have a basic heater without temp. control and it's wired straight from the battery so I can get the pressure to 1200 and let it fall a bit without having to deal with it. If it does fall too far I can turn the heater back on.
:seeya
Old Apr 11, 2002 | 11:21 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
I wired mine directly to the battery, by-passing the ignition switch. So the heater will still work with the motor turned off.
Just don't forget to turn off the heater when you're done.
:cheers:
-Tuan
To Bottle heater question
