1/4 expectations on nitrous
Old Jan 31, 2011 | 02:04 PM
Badd LS6's Avatar
Badd LS6
Default 1/4 expectations on nitrous
hey guys i drive a 04 z06 and im super excited and super curious what im gonna pull off this spring with the new Kit..my currents mods are LTs,catless x,borla straight pipes,vararam..
My drag pack is gonna consist of drag radials..(havent got them yet..most likely gonna be M/Ts) and with Gto Spares
i have a MAF wet kit going in this spring..i'm gonna start off with a 100 shot and eventually put in 150 jets..
im a pretty good driver at the track and know my shift points well..so far my best run is a 12.2@115 on terrible street tires spinning off the line and tire hop into 2nd..
im thinking around low 11s and HOPING to break a 10
what you guys think?
Old Jan 31, 2011 | 04:01 PM
HP_Addict's Avatar
HP_Addict
I would say 11.7 NA and 11.1 on 100 shot
Get a good tune and practice the launch. You want to see 1.7 60's.
BTW start saving money for the rear end.
Old Jan 31, 2011 | 04:07 PM
Badd LS6's Avatar
Badd LS6
why you say that?..i wont be spraying off the line
btw i recently had a new transmission go in due to warranty work..and i believe the diff was also replaced for warranty work when the previous owner had it..car has 40k miles right now..diff and trans dont have much
Old Jan 31, 2011 | 04:56 PM
98vettedave's Avatar
98vettedave
Get a alloyed (hardened) left side differential out put shaft and a tranny brace,this is good insurance and not overly expensive. Don't count on the stock differential to keep you safe!
Old Jan 31, 2011 | 08:15 PM
HP_Addict's Avatar
HP_Addict
sticky tires+hard launch = broken parts spray or no spray
BTW: I have broken 2 rear ends and one had a brace and both output shafts. Broke 3 teeth off the ring gear that time.
Not saying you will break, but don' t be surprised if you do.
Old Jan 31, 2011 | 09:00 PM
Warp Factor's Avatar
Warp Factor
You can get almost any power level you want with nitrous. As with any other power enhancing options, consider convenience, and engine and driveline breakage.
I've use various nitrous applications on various things for years, but my C5 doesn't have it yet.
Old Feb 1, 2011 | 10:37 AM
98vettedave
I forgot to add,get a clutch that can be slipped like a McLeod street twin...clutches that can't be slipped result in carnage. Also, don't over size your DR's,there's no need because a slight wheel spin saves parts. I run Hoosier 275 40 17 DR's with 606/589 when on the nitrous...set up has a .6 delay for nitrous activation allowing the car to hook without to much stress on the drivetrain. We all still break parts,but being smart about your set up will definitely minimize the carnage.
Old Feb 1, 2011 | 11:34 AM
Badd LS6's Avatar
Badd LS6
ill deff keep that in mind when i get my DRs..im gonna tell my tuner to do the 1st shift delete on the spray..im hopen to come across some thin spokes or wagon wheels with DRs so i can just use my stock setup with the super cars for street use
To 1/4 expectations on nitrous
