Need advice...
Feb 2, 2011 | 03:05 PM
Need advice...
My goal is between 500 -550 HP
99 C5 coupe, with LT headers, HF cats, CAI, tune. Stock tranny, rear end, and engine (76K miles on it).
I do not track or drag it. Its a weekend toy for me. Drivability and reliability (as much as possible) is important.
SC or turbo? Thanks for your help
Feb 2, 2011 | 03:07 PM
SC is much more simple on our cars.
You are in California so get the A&A kit and call it a day, you will hit 500 whp no problem
Feb 2, 2011 | 07:36 PM
SC is a no brainer for you. Don't get greedy on that stock motor either.
Feb 2, 2011 | 07:46 PM
Quote:
Originally Posted by
Milan
Exactly, give Steve or Andy a call, 888-838-8377.
Feb 2, 2011 | 08:39 PM
Arun@CCP
Feb 2, 2011 | 08:47 PM
Arun@CCP
That what I did, as soon as I get the car back from the tuner I'll post up some numbers but there are lots of examples on the forum making those numbers with several different systems.
Feb 2, 2011 | 08:59 PM
I was hoping you wanted to actually make some power
Feb 3, 2011 | 03:43 PM
Feb 3, 2011 | 05:22 PM
amidei
Cam/Heads/nitrous
That's the worst advice you can give someone who doesn't go to the track
Feb 3, 2011 | 06:15 PM
Stock tranny was listed, is it a automatic or manual? If it is a automatic you will need to upgrade to handle the added horsepower even if you don't go to the track or drag strip, if its a manual you will need to upgrade to a clutch that will handle the added hp. My two cents.
Feb 3, 2011 | 06:32 PM
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
dbbspider
Supercharger! Come on out, the weather's fine!
Feb 3, 2011 | 06:48 PM
either TTIX w/6765s or YSI w 8rib/flip
Feb 3, 2011 | 11:06 PM
Slow Z06
Plus a 150 shot first stage, 250 second
Feb 4, 2011 | 01:01 AM
mmartinez, the car is a MN6. I'm probably going with the LS7 clutch upgrade, unless you guys recommend another brand.
I know the cost of the A&A kit installed is approx $6500 - $7000
How much would a twin turbo installed cost approx? I was looking at the UPP's setup. What's your thoughts on that kit, slowZO6?
Feb 4, 2011 | 01:46 AM
A TT car in California sounds like a nightmare to me. Has it been done?
Feb 4, 2011 | 09:39 AM
mmartinez
Wrong
Feb 4, 2011 | 09:41 AM
tail_lights
