***RSD NHRA Roll Bar***
We have them in stock and ready to ship to you. They install in just a few hours in your garage or driveway, no lift required. You don't even have to remove the seats!! They come with all the hardware needed to install, and included is a complete instruction manual with pictures.
Also available in 6 point W/Passenger door bar
The Top still stores in the stock location perfectly.
Buy them here for Just $1,150!! plus Shipping
http://www.racespecialtydesigns.com/product.php?productid=126&cat=83&page=1
Steve@RaceSpecialtyDesigns.com
Seriously, mine was easy (depending on your backyard mec skills) to install and I think a way better mounting solution for 5pt/6pt belt systems. I was amased at how the 4 mount pads lined up with the right spots on the frame. Search for pics posted before.
http://www.wolferacecraft.com/detail.aspx?ID=205
edit: here is a more representative 5 point setup: http://www.wolferacecraft.com/detail.aspx?ID=203
The rear bars bolt on which is not legal. So to make it legal you must install it and then have it welded in place. You will ruin that area of powder coating. So you must Paint inside your car. The Wolf Bar has swingout door bar as a $110 optional.
The RSD Roll Bar comes fully welded and assembled, powder coated, and allows full travel of both seats. Easy to install, no welding required. The RSD does not require removal of the seats or the carpets, you will have to move some carpeting out of the way to drill, some carpet trimming is done after ionstall.All of the RSD 5 point Roll Bars come standard with a swingout/ Removable door bar.
The RSD as a 5 point is 4130 Chrome Moly, weighs only 42 lbs and installs in your driveway with simple hand tools and a drill. No lift required and no welding or painting. Comes coated with a really tough Powder Coat that is a rich semi gloss black.
The Wolfracecraft is a well built unit. So is the RSD.
You can't really compare prices with Wolfe straight across. Ours is NHRA ready, Wolfecraft requires welding before it is legal, ours is standard with removanle/swingout door bar, Wolfe has it as a $110 option.
Group buys ususally peter out from my experience. I think people
overestimate the profit margins of these vendors.
Steve
Steve
I would not build one for 1K unless the volume of units were higher than thay are
Any High HP drivers Drag, Road Race or dumbasses on the street need this extra saftey PERIOD.
Steve
I know wolfe runs a special where their setup is priced around 890ish
