wideband install question
Old Feb 10, 2011 | 06:06 PM
Vettedriver986's Avatar
Vettedriver986
Default wideband install question
where in the firewall are you guys running your wires through from the interior to the engine bay? are you doing it on the drivers side or passenger side?
Any pics?
Old Feb 10, 2011 | 06:13 PM
YeloFevr's Avatar
YeloFevr
Any pics?
Which wires need to go to the engine bay? Power source under the steering column, O2 down the tunnel.
Old Feb 10, 2011 | 07:11 PM
joshtownsend's Avatar
joshtownsend
http://www.aacorvette.com/pdf/aa_c5_...structions.pdf
page 6 and 7
Old Feb 10, 2011 | 08:09 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Those are the instructions I used.
Old Feb 10, 2011 | 08:13 PM
Milan's Avatar
Milan
I went through the passenger side, no drilling required that way.
If you remove the battery you will see a huge wiring harness going into the cabin, if you remove the electrical tape you will have a lot of room for wires there.
I have my wideband, boost gauge, laser shifter, and meth kit wired through there.
Old Feb 11, 2011 | 12:06 AM
Vettedriver986
just finished my ashtray mount gauges. went through passenger side grommet behind battery.
Old Feb 11, 2011 | 12:10 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
There's also the shifter boot method.
To wideband install question
