Pump Gas TT Numbers
Old Feb 12, 2011 | 03:57 PM
PhilsZ51's Avatar
PhilsZ51
Default Pump Gas TT Numbers
I will post the dyno graph when it is emailed to me.
With 10lbs and 10 degrees of timing, it made 670/680. I have to re-work the drain lines though; the scavenge pump doesn't seem to be able to keep up. Clouds of smoke.
Old Feb 12, 2011 | 03:59 PM
J Z06's Avatar
J Z06
Good God that is nuts!!!
Old Feb 12, 2011 | 04:07 PM
venomws7's Avatar
venomws7
Very nice man....
Congrats
Old Feb 12, 2011 | 04:10 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Rock & Roll Mr Phil.Welcome to the turbo world!
Old Feb 12, 2011 | 04:11 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Nice numbers!! Can you give us a little info on the motor?
Old Feb 12, 2011 | 04:27 PM
PhilsZ51's Avatar
PhilsZ51
AES 390, stock LS6 heads, 10:1 compression, and ECS blower cam.
Old Feb 12, 2011 | 04:28 PM
RockJustBelow's Avatar
RockJustBelow
What scavenge pump are you using?
Old Feb 12, 2011 | 04:36 PM
PhilsZ51's Avatar
PhilsZ51
Turbowerx base pump. But my lines are routed pretty crappy; they come off the turbo, go down, and then up and over, down to the scavenge pump. It is tough trying to get the lines to go down to the scavenge pump with the turbos being in the fenders.
Old Feb 12, 2011 | 06:05 PM
Slow Z06's Avatar
Slow Z06
Freaking sweet Crank that bad boy up to 20# with 19deg timing and a dual meth setup
Get those oil lines straightened out and let her breathe!!
Old Feb 12, 2011 | 06:20 PM
Smoove's Avatar
Smoove
..not too bad of power numbers... what kit is it? What sized turbos?
Old Feb 12, 2011 | 06:21 PM
PhilsZ51's Avatar
PhilsZ51
I will eventually, but not anytime soon(May). I leave for OCS in 6 days.
Old Feb 12, 2011 | 06:32 PM
Milan's Avatar
Milan
Why such high compression on a turbo car? Are you planning on E85 in the future?
Old Feb 12, 2011 | 08:38 PM
PhilsZ51's Avatar
PhilsZ51
The turbos are 6665s and it's a HP kit. I was going to run the car on E85... Until I realized Pensacola doesn't have a pump within 200 miles. Doh!
Old Feb 12, 2011 | 08:52 PM
TracyRR's Avatar
TracyRR
hey phil, make sure you have a check valve on the scavange side.... if not, oil will drain back in the turbo's and will smoke. Congrats on the big low boost numbers!!
Old Feb 12, 2011 | 10:31 PM
golfinz's Avatar
golfinz
Nice man! How do you like it compared to your novi setup?
Old Feb 12, 2011 | 10:53 PM
PhilsZ51's Avatar
PhilsZ51
I love the TTs. The sound is amazing and it hits like a ton of bricks.
Old Feb 12, 2011 | 10:57 PM
Slow Z06's Avatar
Slow Z06
To Pump Gas TT Numbers
Old Feb 12, 2011 | 11:00 PM
Smoove's Avatar
Smoove
low compression is a thing of the past.
Old Feb 12, 2011 | 11:23 PM
PhilsZ51's Avatar
PhilsZ51
Couldn't say it better myself!
Old Feb 13, 2011 | 12:30 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Congrats Phil! It's nice to see your adventure finally produce some results that you can enjoy. That's great power for only 10psi boost.
