Vortech Blower question
Old Mar 2, 2011 | 11:04 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default Vortech Blower question
I have a Vortech SQ S-trim blower that will need to be re-built pretty soon (getting a little noise and a small oil leak)
I'm considering having the internals upgraded to the SI-trim unit
According to the website, My S trim has the following specs:
Max Speed:
50000 RPM
Max Boost:
20 PSI
Max Flow:
1000 CFM
Max Power:
680 HP
Peak Efficiency:
72%
The SI trim has slightly better numbers:
Max Speed:
52000 RPM
Max Boost:
22 PSI
Max Flow:
1150 CFM
Max Power:
775 HP
Peak Efficiency:
78%
Considering they both fit in the same size housing, I'm curious where the extra efficiency and flow come from. Does this have to do with transmission gear ratios?
Second is it worth the ~$350 to upgrade to the SI trim or will i notice a difference at all?
thanks.
Old Mar 3, 2011 | 10:44 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Different compressor blade on the SI trim.
Only worth it if you're planning on using the extra power and you're not going to miss your house payment or electric bill this month over the extra 350.00.
Old Mar 3, 2011 | 11:05 AM
Mike04's Avatar
Mike04
Is the $350 in addition to what it would cost to rebuild your current SC?
I'd upgrade it while I had it at Vortech... I have issues though
Old Mar 3, 2011 | 06:15 PM
TheRadioFlyer
Supporting Vendor
What I'm hoping for is the increased airflow and efficiency will bring boost sooner in the power band without significantly affecting top-end boost levels.
QUOTE=Mike04;1576949231]Is the $350 in addition to what it would cost to rebuild your current SC?
[/QUOTE]
Yes
Old Mar 3, 2011 | 06:43 PM
BLOWNBLUEZ06
That's easily done with a restrictor plate or a small, undersized, dirty air filter
Old Mar 3, 2011 | 06:48 PM
TheRadioFlyer
Supporting Vendor
I'm also considering a custom-built impeller in place of th SI upgrade by vortech. It's a couple hundred more, but compared to the vortech impeller it looks like it would be WAY more efficient.
http://www.928motorsports.com/parts/...h_impeller.php
Old Mar 3, 2011 | 07:14 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Don't be fooled by the looks. Vortech has a ton of money in the impeller design software. The impeller in the picture is the (old) SC-Trim, which is a cut down (old) S-Trim impeller. I cannot believe that the 928 impeller would even get close to the 78% efficiency range of the Si-Trim.
Old Mar 3, 2011 | 09:23 PM
TheRadioFlyer
Supporting Vendor
From what little pictures i've been able to find, I cannot see a significant difference between the S-trim and Si-trim impellers.
The SI trim appears to still have the straight vanes of the S-trim:
http://www.aacorvette.com/blog/wp-co...02/si-trim.jpg
Old Mar 3, 2011 | 10:23 PM
Z06ster's Avatar
Z06ster
Originally Posted by theradioflyer
I have a Vortech SQ S-trim blower that will need to be re-built pretty soon (getting a little noise and a small oil leak) ....
Radioflyer, I would really like to know how many miles did you have on the Vortech blower before it started leaking? I just made the switch to a Vortech head unit because my Procharger started leaking bad at a mere 30K miles of use. I am hoping the Vortech will go much further than that.
Old Mar 3, 2011 | 10:48 PM
94-vette's Avatar
94-vette
Max Speed:
50000 RPM
Max Boost:
20 PSI
Max Flow:
1000 CFM
Max Power:
680 HP
Peak Efficiency:
72%
Max Speed:
52000 RPM
Max Boost:
22 PSI
Max Flow:
1150 CFM
Max Power:
775 HP
Peak Efficiency:
78%
thanks.
http://www.musclemustangfastfords.co...ger/index.html
The answer is yes and very worth it.
Old Mar 3, 2011 | 10:53 PM
TheRadioFlyer
Supporting Vendor
I'm not sure. I bought it pre-owned.
Old Apr 1, 2011 | 12:33 AM
TheRadioFlyer
Supporting Vendor
I decided to be patient and sent the blower to vortech for a rebuild. Good thing too since the gears were pretty warn down. While i'm not exactly happy about the bill, but it beats buying a new blower and plus i got the Si-trim upgrade.
The rebuilt blower is so quiet, you'd have to listen really hard to know the car has a supercharger. I also installed a custom aluminum restrictor plate that reduced the ID of the intake from about 3.25" to 2.875" to limit top-end boost.
Initial impressions....the S-trim is freaking incredible. I'm seeing about 1-1.5 pounds more boost at the same throttle level as the S-trim....and thus it puts power right where I want it. I haven't really gotten on it hard yet and won't do that until i get the new RX dual valve catch installed so I'm not throwing oil-vapor into my new blower.
Old Apr 1, 2011 | 07:10 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Steve's the MAN--He should KNOW!!!!!
Old Apr 1, 2011 | 11:56 AM
Former Vendor
:o
PM Sent.
Old Apr 1, 2011 | 04:14 PM
stevieturbo's Avatar
stevieturbo
I want to know when the blower guys are getting some of these new fancy billet compressor wheels for our superchargers !!
Every turbo unit is getting them, so surely there must be improvements available for the SC users ?
Old Apr 1, 2011 | 11:01 PM
94-vette's Avatar
94-vette
I tried to told ya!
Old Apr 1, 2011 | 11:38 PM
TheRadioFlyer
Supporting Vendor
Originally Posted by 94-vette
I tried to told ya!
yea...i had that coming...
To Vortech Blower question
Old Apr 1, 2011 | 11:48 PM
94-vette's Avatar
94-vette
Now can I get a hook up on the HID fogs?
Old Apr 1, 2011 | 11:53 PM
TheRadioFlyer
Supporting Vendor
Do you have factory fog lights?
Old Apr 2, 2011 | 01:07 AM
94-vette's Avatar
94-vette
No C5Z
