need belt advice..
Old Mar 9, 2011 | 11:26 PM
ez2spd's Avatar
ez2spd
Default need belt advice..
Procharger was not much help as the part numbers they provided don't show such belts... I have a 8 rIb f1c 7.5" crank pulley and 4.5" previous belt was k080903hd with 5" sc pulley... belt fits with this pulley but I'm having massive belt slip thus they recommended k080895... called jegs and summit and they can't cross reference anything for it... I just need belt that is 1 to 2" smaller.... tensioner is maxed out...any help or advice is GREATLY APPRECIATED... checked gatorback and gates With no luck....
Old Mar 10, 2011 | 01:24 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You're .2" off on your part#
Try K080893HD at Woodys auto supply for 43.00
Old Mar 10, 2011 | 07:08 AM
ez2spd's Avatar
ez2spd
got it!!!! Sir, you have been a tremendous help, its greatly appreciated once again...
-Brian
Old Mar 10, 2011 | 07:30 AM
BLOWNBLUEZ06
-Brian
Just helping a fellow Texan
I wasn't born here, but I got here as quickly as I could.
Old Mar 10, 2011 | 10:16 AM
ez2spd's Avatar
ez2spd
Born and raised... made my way from Austin to San Antonio :P
Old Mar 10, 2011 | 08:48 PM
ez2spd's Avatar
ez2spd
installed inch smaller belt K080893 and I can twist the best * on alt side * almost a 1/2 turn to show the rib side.... WHATTTT AM I MISSING HERE!!! tentionor is MAXED OUT and IMO the way the belt tightens is the worst invention * WORST THAN THE SMART CAR * tell me how a GRADE * bolt 1/4 inch thick bends....
Old Mar 10, 2011 | 08:54 PM
ez2spd's Avatar
ez2spd
possibly another inch or two smaller belt....
http://www.gatespowerpro.com/Comerge...TOKEN=97369969
anyone ever have this same problem this site has helped TREMENDOUSLY....
with this setup 4.5" pulley I should see 8lbs boost... I see 2lbs MAX!!! most of the time I cant even hit that....
Old Mar 11, 2011 | 09:55 PM
ez2spd's Avatar
ez2spd
On belt number 4 either too big and belt slips or too small and won't fit...
Old Mar 11, 2011 | 10:35 PM
4DRUSH's Avatar
4DRUSH
You do realize the last numbers are the length of the belt.
890 = 89"
895 = 89.5 "
ect.
Shouldn't be too hard to get the right size belt after trying a couple?
BTW- one of this days you should get a better bracket setup.
Old Mar 11, 2011 | 10:58 PM
a/c man's Avatar
a/c man
try this http://www.exoticperformanceplus.com...html?item=1077
when i had a procharger i ran a 88" you want the smallest belt you can force on it!!
Old Mar 12, 2011 | 01:20 AM
ez2spd's Avatar
ez2spd
Yep I know about the last 2 numbers... but problem was the 89'' was so loose I could twist it one full turn so I went 2 sizes smaller being the 87'' but it was too tight by half an inch ''with out tentioner as a factor'' too small... couldn't get it over pulley... but the first problem was calling procharger and them recommending the wrong size... now I have an 88'' belt over nighted from Houston it will be PERFECT...
Old Mar 12, 2011 | 01:22 AM
ez2spd's Avatar
ez2spd
I AGREE with bracket swap... next project will def be that in the coming month... thanks again for the help guys its been greatly appreciated... new to forced induction and its been a warm welcome into the new world...
Old Mar 12, 2011 | 01:28 AM
ez2spd's Avatar
ez2spd
http://www.c5racer.com/catalog/corve...r-bracket.html
Old Mar 12, 2011 | 11:51 AM
a/c man's Avatar
a/c man
yea i upgraded to the A&A procharger bracket works awesome!
i found it easy to install the belt if i put it on all the pulleys and slid it over the water pump last!
Old Mar 13, 2011 | 01:08 PM
ez2spd's Avatar
ez2spd
Aside from gates who else makes 8rib 88" belt... pt number k080876 no one has been able to help... 89 is way big and 87 is too tight to fit.... gatorback etc... what belt do you use!?
Old Mar 13, 2011 | 01:30 PM
a/c man's Avatar
a/c man
gates from napa
Old Mar 15, 2011 | 08:11 PM
ez2spd's Avatar
ez2spd
Got belt!!!! Ordered from car quest boost is now 5lbs... with pulley set up its perfect now...
Old Mar 15, 2011 | 08:33 PM
4DRUSH's Avatar
4DRUSH
Old Mar 16, 2011 | 11:59 AM
fsuforever's Avatar
fsuforever
i use to run the gates black belt, but have learned of the greenback fleet runner belt made by gates , with the kevlar reinforcment , now that is all i run
To need belt advice..
