Progressive Nitrous Controller
Old Apr 15, 2002 | 05:20 PM
numtin's Avatar
numtin
Default Progressive Nitrous Controller
I am thinking about going with a controler, but the only one I know of is the NX Maximizer Controller.
What other controlers are there? and how much do they cost?
thanks for your help
Old Apr 15, 2002 | 06:56 PM
99 Corvette's Avatar
99 Corvette
Default Re: Progressive Nitrous Controller (numtin)
Be careful. Controllers pulse your noids to control the flow. It helps you launch but IMHO it is too much wear on the seals on your noids :smash:
Jerry
Old Apr 15, 2002 | 08:28 PM
bruce1's Avatar
bruce1
The "Maximizer" is the only one I know of with the Nx Express system....
Old Apr 16, 2002 | 11:32 AM
TS 2000's Avatar
TS 2000
I just took the NX system out of my car, including the NX Maximizer controller. Everything is in perfect condition. If your interested in purchasing it, let me know....
asabella2@attbi.com
[Modified by TS 2000, 9:33 AM 4/16/2002]
Old Apr 18, 2002 | 08:38 PM
K&B Motorsports's Avatar
K&B Motorsports
Default Re: Progressive Nitrous Controller (TS 2000)
I use the NOS progressive controller and use a safety solenoid on the n2o side to assure it will shut off just in case the pulsing noid toasts.
Old Apr 19, 2002 | 08:51 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Default Re: Progressive Nitrous Controller (K&B Motorsports)
I planning on doing similar setup, dual nitrous solenoids in series and dual fuel solenoids in parallel.
:cheers:
-Tuan
Old Apr 29, 2002 | 09:11 PM
bparker's Avatar
bparker
Is it just me (I am new to N20) or would it be obvious for MSD, NX, NOS, Malory, Etc.. to build a progressive controller that is based off of the RPM wire/computer? Rather than a "timer"? This would encompass a prog controler + a window switch.
And why stop there? They could put in Air/Fuel Ratio controls, Throttle Pos Sensor stuff, etc..??
If this unit was an "all in one" wouldnt that be the way to go? Or is that a perfect world in which we do not live in right now?
Over, :confused:
Old Apr 29, 2002 | 09:19 PM
akw408's Avatar
akw408
Default Re: Progressive Nitrous Controller (bparker)
I believe the Jacobs Mastermind is based off of RPMs.
Yes that would be an ideal setup. An all in one controller, with options to use and not use certain things.
To Progressive Nitrous Controller
