Trans removal
Old Mar 21, 2011 | 01:18 PM
C5sleeper's Avatar
C5sleeper
Default Trans removal
Going to be doing trans install I believe this weekend I did a search and couldn't find a straight answer. I want to pull the trans and converter to swap in my stage 6 rpm, vigilante converter 3000. Can I do this without dropping the torque tube? I really don't want to drop the torquetube because of the extra work... Let's hear you input guys and any tipsand tricks.
I will be using a 2 post lift with a few buddys.
Old Mar 21, 2011 | 07:26 PM
joshtownsend's Avatar
joshtownsend
I'M pretty sure you have to take out the TT.. in 6 sp, the clutch is on the back of the motor... if the converter is no there, then yes, it can be done easily without taking the TT out.
Old Mar 21, 2011 | 07:30 PM
C5sleeper's Avatar
C5sleeper
Yea converter is mounted in the rear, at the back of the TT. So i would assume with that being left as it is and just unbolted it can be done?
Anything i should lookout for in these?
Old Mar 21, 2011 | 07:34 PM
joshtownsend
4 bolts on cradle, disconnect wires,TT bolts, one 10mm ground, and 2 brake lines right above the trans, and pull it apart.. simple and simple
Old Mar 21, 2011 | 07:40 PM
Slow Z06's Avatar
Slow Z06
werd
Old Mar 21, 2011 | 07:47 PM
C5sleeper's Avatar
C5sleeper
Can you hang the calipers or do you have remove those lines entirely
Old Mar 21, 2011 | 08:07 PM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
just hang the calipers
you can even leave the mufflers up in place, just take zip ties and tie them up to the fuel tank covers
Old Mar 21, 2011 | 11:12 PM
396375's Avatar
396375
St. Jude Donor '08-'09
This is for a 6 speed.Once you get close the auto is almost the same.With a 2 post it will be even easier.I did mine 2 years ago and it was my first big job on a C5.NP.You can also Google "remove transmission C5 Corvette."Always keep the motor supported right through the whole procedure.Good luck.
http://www.cajundude.com/differential.htm
Old Mar 21, 2011 | 11:31 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No need to drop the torque tube. Just pull the rear plug on the TT housing and unbolt the converter.
Disconnect all of the cables, connectors, etc... and drop it down.
I would drain transmission and lines before beginning.
Old Mar 21, 2011 | 11:36 PM
jmoody66's Avatar
jmoody66
If it were me I would go ahead and remove it, replace the bearings and bushings in it and be done for another xxxxx miles. My bearings were going out on mine!
Old Mar 21, 2011 | 11:39 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
That's because your car is running a blower making big horsepower and torque.
Old Mar 22, 2011 | 09:54 AM
C5sleeper's Avatar
C5sleeper
Yea I'm about 520 hp so I'm not there yet
Old Mar 24, 2011 | 01:27 AM
reactor2's Avatar
reactor2
Dropping the tranny is pretty simple. I did it with the car on jackstands, in my garage, without any help. You don't need to drop the torque tube.
To Trans removal
