new numbers after changing intake
Old Mar 23, 2011 | 06:13 PM
tail_lights's Avatar
tail_lights
Originally Posted by 03redzo6
pictures added to first post
Old Mar 23, 2011 | 07:36 PM
Its Bruce's Avatar
Its Bruce
14.6psi
Old Mar 23, 2011 | 09:12 PM
dsmlights's Avatar
dsmlights
woww nice numbers man, I can't wait to put mine up to 13-14 psi .What pullye are you running. We made pretty much same power made 639.
Old Mar 23, 2011 | 09:56 PM
03redzo6's Avatar
03redzo6
its the 3.8 pulley but im also using the innovative 8 rib setup with the overdrive crank balancer
Old Mar 23, 2011 | 10:27 PM
jmuck's Avatar
jmuck
Which radiator did you use?
Old Mar 23, 2011 | 11:03 PM
a/c man's Avatar
a/c man
Anyone ever cut down a Dewitt radiator? i think it could be done??
Old Mar 24, 2011 | 12:49 AM
03redzo6's Avatar
03redzo6
its a dewitts shorter radiator
dewitts sells shorter radiators specifically for the supercharged guys
Old Mar 24, 2011 | 09:35 AM
jmuck's Avatar
jmuck
Thanks for the info.
Old Mar 24, 2011 | 10:23 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Awesome increase and getting rid of the dongle is a no brainer mod for those wanting more HP
Old Mar 24, 2011 | 11:02 PM
03redzo6's Avatar
03redzo6
Old Mar 25, 2011 | 12:00 AM
a/c man's Avatar
a/c man
Great numbers after the new mod!!!!!!!!!I still would like to find out if anyone has ever cut down a stock Dewitts radiator? only reason is because thats what i already got! and would hate to buy new!
Old Mar 25, 2011 | 01:16 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
When I ditched my set-up and went to the 4" Inlet Pipe I picked up 3.2 PSI of Boost and felt all the difference in the world -
Did the re-tune and went from 639 RWHP to 701 RWHP, nice safe tune too!
Thanks,Matt
Old Mar 25, 2011 | 01:18 PM
  #33
dykz34's Avatar
dykz34
There would be gaps in the radiator side tanks that would need to be welded shut. It's possible if you can TIG weld.
Old Mar 25, 2011 | 01:25 PM
  #34
madmatt9471
Do what I did and buy the A&A radiator lowering kit!
So there is really no need to cut the radiator down, just get the brackets to slide the bottom of the radiator forward which will lower the top of the radiator down to where it needs to be for the 4" pipe
Thanks,Matt
