Issues please look!
Old Mar 28, 2011 | 05:23 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Default Issues please look!
http://forums.corvetteforum.com/c4-t...post1577188597
Old Mar 28, 2011 | 05:50 PM
1SikVette's Avatar
01SikVette
Former Vendor
If you can smell fuel there's your issue. You might want to look over fuel lines carefully. Have you checked to see if fuel is leaking at the back of the car where the fuel hat is? Do you have a fuel pressure gauge?
Old Mar 28, 2011 | 05:54 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Fuel pressure is fine. Reads what it normally reads about 57 psi or so at an idle.
Old Mar 28, 2011 | 07:24 PM
Milan's Avatar
Milan
If it sounds like a Subaru that sounds to me like a broken ringland....not sure how this would explain your fuel consumption
Old Mar 28, 2011 | 09:24 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
let's not assume the worst. Let's talk and get you through this. It's quite possibly a simple, inexpensive problem.
Old Mar 28, 2011 | 09:26 PM
Mike04's Avatar
Mike04
did you check to see if the engine has any codes?
I would go over your fuel lines from the tank to the rails and see if you can find a leak. Most of it is in the tunel, use your nose to see if there is an area that it is the strongest. I'd think twice about driving it if there is a few leak.....
Old Mar 28, 2011 | 09:27 PM
Its Bruce's Avatar
Its Bruce
Was it blowing rich/black smoke out the exhaust?
Old Mar 28, 2011 | 11:21 PM
MVP'S ZO6's Avatar
MVP'S ZO6
Talked to Brett today (blownbluezo6) and I'm going to inspect the plugs and closely inspect the injector wiring harness. As well as possibly do a compression test if the above don't fix it. I will also pull the valve covers and check for a broken spring and replace fuel filter if the above springs are not broke and the harness looks fine and the plugs aren't soaked.
Old Mar 29, 2011 | 12:22 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Cars on a tow truck on it's way home.
Old Mar 29, 2011 | 12:32 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Tagged! to help, gotta see other page, but want to be linked. I'll be back!
Thanks,Matt
Old Mar 29, 2011 | 12:36 AM
madmatt9471
Your original post from C4 section!
Issues please look.
Ok so I was driving to work everything was good to go. I get off the interstate and stop at a light. When I went to take off the engine sounded like a wrx boxer engine. I can smell fuel and the car is ironing like crap and has reduced power. No check engine lights oil pressure is good cooling temp is normal. No signs of a fuel leak
It's consuming gas at an alarming rate a quarter tank in 40 miles.
Blown 383 stroker upgraded everything.
It sounds like the injectors are hanging wide open and drowning the cylinders, giving the reduced power, and the aweful sound -
Will be looking for investigative results on the plugs!
Were you doing anything to the Vette previously, like working on it etc. any recent changes?
Thanks,Matt
Old Mar 29, 2011 | 01:12 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Issues please look.
Thanks,Matt
Matt. No work done this far. I was going to change the oil this week but that's it.
I'll post as I find out more.
To Issues please look!
