Codes after AA install
Old Mar 28, 2011 | 08:25 PM
dc491's Avatar
dc491
Default Codes after AA install
Below are codes that I am getting from the TCS. I have reset them once and they came back. I will try to reset they again and see what happens. I did not unhook the steering rack during the install or mess with any wires that I know if that would have to do this. If anyone has seen these codes before or knows a good starting point please advise. I posted on this side of the forum because I thought this might be related to the install. If not I'll move to the tech forum. Thanks Dave
C1281 H Steering Sensor Uncorrelated Malfunction
C1286 H C Steering Sensor Bias Malfunction
Old Mar 28, 2011 | 08:50 PM
dc491's Avatar
dc491
I did not drop the rack at all I will check that harness though. Where exactly is it located? I think I might have a yaw rate sensor problem. If I clear the code it does not come on immediately.
Old Mar 28, 2011 | 09:07 PM
backnblack2003z06's Avatar
backnblack2003z06
I'm not sure what happened to my post, but the wires come of the rack where the steering shaft bolts on, but looking over the diag chart for the codes I don't think thats the problem. Here is the chart from the service manual.
DTC C1281, C1283, or C1286
Circuit Description
The vehicle stability enhancement system (VSES) is activated by the electronic brake control mdoule (EBCM) calculating the desired yaw rate and comparing it to the actual yaw rate input. The desired yaw rate is calculated from measured steering wheel position, vehicle speed, and lateral acceleration. The difference between the desired yaw rate and actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. If the yaw rate error becomes too large, the EBCM will attempt to correct the vehicle's yaw motion by applying differential braking to the left or right front wheel.
The amount of differential braking applied to the left or right front wheel is based on both the yaw rate error and side slip rate error. The side slip rate error is a function of the lateral acceleration minus the product of the yaw rate and vehicle speed. The yaw rate error and side slip rate error are combined to produce the total delta velocity error. When the delta velocity error becomes too large and the VSES system activates, the drivers steering inputs combined with the differential braking will attempt to bring the delta velocity error toward zero.
The VSES activations generally occur during aggressive driving, in the turns or bumpy roads without much use of the accelerator pedal. When braking during VSES activation, the brake pedal will feel different than the ABS pedal pulsation. The brake pedal pulsates at a higher frequency during VSES activation.
Conditions for Running the DTC
C1281
• The steer angle has been centered.
• The VSES is active.
• The direction (understeer or oversteer) of the delta velocity error has not changed.
• The centered lateral acceleration value is less than 0.5 g.
• The yaw rate error is less than 6 degrees/second.
• The side slip error is greater than 1.8 meters/second*second.
C1283
The vehicle speed is greater than 40 km/h (25 mph).
C1286
Conditions for Setting the DTC
C1281
One of the following conditions exists:
• The VSES is engaged for 10 seconds with the delta velocity error always in either understeer or oversteer. Under this condition, this DTC will set by itself.
• The yaw rate error is greater than 10 degrees/second for 5 seconds. Under this condition, this DTC will set along with DTC C1282.
• The yaw rate error is greater than 10 degrees/second with the vehicle speed less than 60 km/h (37 mph) and the acceleration pedal is pressed more than 25 percent of the pedal travel range for 1 second during the VSES activation. Under this condition, this DTC will set along with DTC C1282.
• With the yaw rate less than 8 degrees/second, the side slip error is greater than 4.9 meters/second*second for 5 seconds. Under this condition, this DTC will set along with DTC C1284.
• With the vehicle speed greater than 10 km/h (6.2 mph) and less than 100 km/h (62 mph) and the centered yaw rate has a value that is positive and is greater than 10 degrees/second, the oversteer term is negative for 2 seconds. The oversteer term is the yaw rate value times the lateral acceleration value. Under this condition, this DTC will set along with DTC C1284.
• With the steer rate less than 80 degrees/second, the difference between the 2 steering sensor signals (Phase A and Phase B) is greater than 20 degrees for 1 second. Under this condition, this DTC will set along with DTC C1287.
C1283
The vehicle has driven for 10 minutes without completing steer angle centering.
C1286
The steering sensor bias moves greater than 40 degrees after steer centering was accomplished.
Action Taken When the DTC Sets
• The EBCM disables the VSES for the duration of the ignition cycle.
• The Traction Control and Active Handling indicator turns ON.
• The DIC displays the Service Active Handling message.
• The ABS remains functional.
Conditions for Clearing the DTC
• The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
• The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
• The scan tool may display 2 additional characters after the DTC. Take note of the 2 character code and any other DTCs that are set. The 2 character code is an engineering aid used in order to determine the specific criteria which caused the DTC to set.
• During diagnosis, park the vehicle on a level surface.
• Check the vehicle for proper alignment. The car should not pull in either direction while driving straight on a level surface.
• Find out from the driver under what conditions the DTC was set (when the DIC displayed the Service Active Handling message). This information will help to duplicate the failure.
• The Snapshot function on the scan tool can help find an intermittent DTC.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Perform the Steering Position Sensor Test in order to verify that the steering wheel position sensor (SWPS) is operating properly.
Verify that the lateral accelerometer input parameter is within the valid range.
Verify that the yaw rate input parameter is within the valid range.
Step
Action
Values
Yes
No
Schematic Reference: Antilock Brake System Schematics
1
Did you perform the ABS Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, perform the Steering Position Sensor Test.
Did the SWPS pass the test?
Go to Step 3
Go to Step 7
3
With a scan tool, observe the Lateral Accelerometer Input parameter in the VSES data list.
Does the scan tool display within the specified range?
2.3-2.7 V
Go to Step 4
Go to Step 8
4
With a scan tool, observe the Yaw Rate Sensor Input parameter in the VSES data list.
2.3-2.7 V
Go to Step 5
Go to Step 9
5
Use the scan tool in order to clear the DTCs.
Perform the Diagnostic Test Drive. Refer to Diagnostic Test Drive .
Does the DTC reset?
Go to Step 6
Go to Diagnostic Aids
6
Replace the EBCM. Refer to Electronic Brake Control Module Replacement .
Did you complete the repair?
Go to Step 10
7
Replace the steering wheel position sensor (SWPS). Refer to Steering Shaft, Lower Bearing, and Jacket Replacement in Steering Wheel and Column.
Did you complete the replacement?
Go to Step 10
8
Replace the lateral accelerometer sensor. Refer to Lateral Accelerometer Replacement .
Go to Step 10
9
Replace the yaw rate sensor. Refer to Vehicle Yaw Sensor Replacement .
Go to Step 10
10
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
To Codes after AA install
