I have an A&A kit in my car and was reading about the 4 inch stainless steel dongles guys make and get good results with. I have a normal height Dewitts radiator how hard would it be to fit a 4 inch dongle? Also, how would a 3.5 inch dongle work the vortech site says the Si has a 3.5 inch inlet. Can more power be made with a 3.5 inch dongle over the one in my car for A&A?
Thanks,
Rob
The 4in stainless steel pipe will not work with the org size radiator.
Thats what I was reading I saw where guys lay down the radiator to get clearance I wonder if its to much work to bother with it.
Rob
Not to bad just cut and re-welding of the rad bracket. Look over in the for sell part one guy has a set up for 100.00. and a few write up for the subject also.
Thanks,
Rob
Curious about if we should go with the 3.5 or 4" for the Si 3.5 inch inlet?
The less restriction in front of the supercharger, the better and more power you'll be able to make.
Agreed... I remember reading that the 4" pipe gave some good increases / better flow over the A&A dongle that we got - but I guess I was wondering if a 3.5" pipe would show much improvement / or not / over the A&A dongle - IF anybody had tried to see what the difference was - if any?
I'll take a picture of a 3.5" pipe compared to the A&A dongle tonight and post it.
Do you know if it has any affects on cooling with the radiator layed down?
Thats what I was thinking would the 3.5 be easier to make fit. Even if its not as good as the 4" if its some improvement and I think it would look better too.
Thanks this may tell a lot about what to expect.
I would get the span fans for it just for ins they put out over 2x as much as the stock ones. Plus I just bought the set up from Arun on here he is a vendor got them at a really good price for them... But back to your quesion I dont think will be any diff I know of 3 or 4 on here and they never posted up any diff in the temp. Robert
Yea pretty certain my blower went in this past July or August.
That's all you need. I guess if you're close to 1K HP at the wheels you may want to figure out a straight 4" piece. That the new design is pretty darn good.
Yea I am no wheres near that power level I think I am good with the dongle I have now. Thanks for setting me straight... Maybe I will be tackling this when I forge the bottom end and step it up to a Y trim
Can you post a pic of this new dongle? I have the plastic dongle on the YSI kit I got today.
