PM Spoonhatch98 (I think that's how it's laid out).
He has a Snow kit.
The best advice I could give you is to get rid of that kit. I firmly believe it's failure contributed to his engine troubles, but just guess.
F*** it, looks like I'm ordering an ecs alky kit. I don't want to risk my engine. Is it ok to use snows boost juice with it? I already ordered 4 gallons of it.
sell it, get some M3 100% meth most race shops sell it
Depends on whether or not you're running a meth reliant tune. If not, then it's ok to run a mixture IMO. This is only because a mixture will affect your AFR's less than pure meth. My preference though is to run straight methanol and lots of it.
I've been running a Labonte progressive controller with a system that I made. It has been very dependable. My tune is not meth dependent though, I just want a little insurance. I also run a 50/50 mix and a #12 nozzle plumbed into my throttle body just in front of the blade. It 's set to come on at 2 lbs. No complaints. Rod
