Hoods/Louvers
Thanks,
The Big Dog
I've been waiting for someone to come out with a hood similar to the ACP hood without the center hump.
I don't think I'd go the Run Cool louvers though.. a little to "rugged" look for a vette.
The NACA ducts feed the turbos directly,...the larger re openings evacuate the heat from the turbos/headers/DP... Everything works,... and it didn't cost me 1500 bucks.
Notice the hood tweak on the bottom.... blown out from the backfire. (hood and headlights are not in final location).
I'm REALLY happy with the overall look,..truly stoked to know that it is going to really work,..as they sit right above the headers,...hopefully while it's moving the air will pass through the turbos and out these hatches.
Hood structure did have to be cut/notched in certain areas. There is just no way around it. I can get the same vents design wise a hair smaller but,...in my eye,...I don't think it would fit right. There small enough to where if I felt I REALLY needed, I could possibly add them to my current equation. But,..no plans currently.
Thanks again, lemme know if you guys need different shots or something.
-J
EDIT-
These DO stick out of the hood probably about a half inch.... if your dying to know(understandable reasons) I can measure it tomorrow, how far they protrude out, no problem.
lemme know.
