Speed density or not???
Old Apr 24, 2011 | 08:50 PM
SCRMNC5's Avatar
SCRMNC5
Default Speed density or not???
Hey guys, with my current set up I'm running a 2 bar SD tune. I can't pass emissions in my state because of it. If 2 cars have the same HP, and 1 has a SD tune and the other doesn't, is there a major difference in performance?? Also if I go back to a MAF, is it better to get a bigger one.
D1SC Pro charger
60 lb injectors
tune,
headers/exhaust
Will I still be happy going back to a MAF
Please help!!!
Barry
Old Apr 24, 2011 | 10:48 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
What is required to pass? Not simply a "ready" status on all items??
If that's the case, then your tune just needs work to achieve that.
Are you aware you can keep the 2-bar SD tune and turn on your MAF?
Old Apr 25, 2011 | 02:08 AM
MR.Z06's Avatar
MR.Z06
D1SC Pro charger
60 lb injectors
tune,
headers/exhaust
Please help!!!
Barry
The short answer is no.
I was tuned SD before my MAF tune.
Old Apr 25, 2011 | 04:21 PM
Higgs Boson's Avatar
Higgs Boson
Only reason to go SD is if you are maxing out your MAF or your cam is so big you have reversion issues.
Old Apr 25, 2011 | 05:06 PM
95vettski's Avatar
95vettski
If tuned properly both should produce the same power. My local shop Champion Motors has produced over 900rwhp with a maf and our pcm's that are limited to 512g!
Old Apr 25, 2011 | 05:14 PM
HP_Addict's Avatar
HP_Addict
I agree. My car made 754 rwhp and still has the stock MAF. Been like that for over 2 years without problem. If I am running it hard I hook up the laptop and monitor the A/F with HP Tuners, but have never had the need to change it.
Old Apr 25, 2011 | 05:56 PM
Erics_02_z06's Avatar
Erics_02_z06
I hear the throttle response is better with SD?
Old Apr 25, 2011 | 06:23 PM
C5blownz06's Avatar
C5blownz06
And I hear its better with a MAF. Depends on who you talk to as everyone has their own opinion. Also the way car is driven, temperatures, humidity, elevation, dew point, whether its a day that has a W in it or there is a full moon out. Oh yea if you are on your cell phone I heard SD is better but only if its as incoming call..
Old Apr 25, 2011 | 06:35 PM
user_name's Avatar
user_name
Power should be the same with either. I can do a more precise and safer tune with an SD tune. Do you want the computer to measure the boost and base fueling on it? The only way to get that with a MAF on a gen3 pcm with more than 500rwhp or so is to scale everything so the computer thinks it is seeing much less air than it really is.
I can't really see much reason to keep a MAF on these cars when boosted if your computer supports the custom OS's (99+). This is from someone who has done both and not just repeating hearsay.
Old Apr 25, 2011 | 06:43 PM
Silverbullet6spd's Avatar
Silverbullet6spd
My MAF was maxed as well, instead of "band-aiding" the tuning or going to speed density, I went with this.http://www.powrmax.com/PowrMAF%20100.html
Old Apr 25, 2011 | 06:46 PM
user_name's Avatar
user_name
You wasted money. The same thing could be achieved through scaling the IFR and VE tables to not max out the hard 512g/sec limit in the gen3 pcm. All you did was lose resolution. 512 is no longer 512.
Old Apr 25, 2011 | 06:51 PM
Silverbullet6spd
I am not a tuning expert, I just know my AFR is right at 50 degrees or 95. I'm happy with it. Besides, my factory MAF had issues anyway.
Old Apr 25, 2011 | 06:55 PM
C5blownz06's Avatar
C5blownz06
As long as the end results are what you want. Most people take their tuners word for everything in their tune, Everyone needs to learn how to tune or at least log their driving or WOT once in a while to check things. There is no way in he** if trust many tuners out there cause ive seen too many tunes where they dont even touch half the tables they should be for $600..
Old Apr 26, 2011 | 12:21 AM
MR.Z06's Avatar
MR.Z06
Old Apr 26, 2011 | 12:38 AM
corvette8189's Avatar
corvette8189
SD=Win
Old Apr 26, 2011 | 01:24 AM
Milan's Avatar
Milan
I'm converting my car this week. We'll see how it goes
To Speed density or not???
