Snow Methanol performance Kits
Old Apr 26, 2011 | 02:34 PM
amidei's Avatar
amidei
Default Snow Methanol performance Kits
What is the best snow(meth) performance kit for a C5 with a centi-vortech blower?
Will I need to get another tune after the kit is installed?
Thankyou for any advice.
Old Apr 26, 2011 | 03:14 PM
corvette8189's Avatar
corvette8189
my advice would be to get a alkycontrol kit, yes get another tune to take advantage of the meth
Old Apr 26, 2011 | 03:32 PM
robert miller's Avatar
robert miller
Nice guy here and will help you on what ever you need. www.alkycontrol.com Robert
Old Apr 26, 2011 | 05:36 PM
amidei's Avatar
amidei
If i am just using the alky control Kit for cooling purposes, can i get away with not doing another tune?
Old Apr 26, 2011 | 05:53 PM
golfinz's Avatar
golfinz
Do not buy the snow kit...the alkycontrol is the only way to go
Old Apr 26, 2011 | 06:46 PM
robert miller
The meth is a good saftey item is all per say. Will let you do more in the tune and cool down the runners 70 to 80 deg... Robert
Old Apr 26, 2011 | 06:48 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
With an alky control kit? Yes.
With a Snow kit? Not so easily done.
Old Apr 26, 2011 | 11:24 PM
p1bz's Avatar
p1bz
Of course you can, spray more water and less meth. The water cools the chamber and reduces egt's considerably and since water is not a fuel, you don't have to tune for it. Just water alone works wonders, buy everybody likes alot of meth, like 2-3 m15 nozzles for the horsepower and extra timing it allows. Nothing wrong with that, but I doesn't seem that is what you are looking for. So, to answer you question, yes Snow is just fine, and spray -20 washer fluid through a m10 nozzle, 4.77cents through McMaster Carr, and you will have extra safety and not much coin spent. I just figured I would try to answer your question without telling you to buy something else.
Old Apr 27, 2011 | 12:46 PM
amidei's Avatar
amidei
Can someone refer a Shop that can handle installing Alky Control Kits or Snow Meth Performance Kits and a Great Tuner in the Northwest suburbs Chicago, IL area?
Old Apr 27, 2011 | 06:04 PM
amidei's Avatar
amidei
Anywhere close to the chicago area?
Old Apr 27, 2011 | 06:41 PM
YeloFevr's Avatar
YeloFevr
Can't help you with a tuner, but just buy the kit from ECS. Installed mine this weekend and I'm very happy with the design of the setup. Nearly fool-proof installation.
Old Apr 27, 2011 | 07:58 PM
amidei's Avatar
amidei
I'll check out ECS. Thanks.
Old Apr 27, 2011 | 09:16 PM
Milan's Avatar
Milan
I have the snow kit...no problems. Also they have great customer service
Old Apr 27, 2011 | 09:34 PM
WDDarts's Avatar
WDDarts
I also have the Snow kit and it works great. I installed mine at the same time I installed the A&A system. When I had it tuned I had the tuner set me up for a safe tune with the meth more for protection. I have had both installed and running great for almost two years. I installed the stage two snow system as I was not looking to make any adjustments on the fly.
Old Apr 29, 2011 | 04:36 PM
amidei's Avatar
amidei
I'm leaning towards the Alky Control Kit by ECS. Can i mix windshield washer fluid w 2-3 cans of Heat?(cheaper boost juice) or do i need to mix(exactly) 50/50 water/methanol? I probably don't want to run 100% Meth.
Thanks for your input!
Old Apr 29, 2011 | 04:46 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I like the 5 gallons of VP M1, nobody can walk by without asking
Old Apr 29, 2011 | 05:47 PM
TorqHQ's Avatar
TorqHQ
We are a snow performance dealer with greart pricing and tons of experience
To Snow Methanol performance Kits
Old May 2, 2011 | 10:35 AM
amidei's Avatar
amidei
Old May 2, 2011 | 12:59 PM
helga203's Avatar
helga203
Is this a serious question?
Old May 2, 2011 | 01:15 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Another Vote for the AlkyControl kit - been using it for a long time and Julio has great customer service
Thanks,Matt
