Info from those using meth injection
Old Apr 28, 2011 | 02:16 AM
stereomechanix's Avatar
stereomechanix
Default Info from those using meth injection
Getting ready to install a meth kit on my procharged vette and needed some info from those of you who have installed meth on your car. The 3 questions that I have are: where is the best place to install the jets/nozzles from a meth kit? Most of the pics I've seen look like people are installing them near the throttle body on the pipe coming up from the intercooler? #2 how large of a tank does someone need? I was looking at a 2 gallon tank from US plastics but I didn't know if that was overkill. And #3 how much meth (or meth/water) do you use per week if not racing the car?
Thanks for any responses.
Old Apr 28, 2011 | 02:21 AM
Milan's Avatar
Milan
1) Before the TB
2) Most people use the WW reservoir
3) I go through about 1 gallon every couple months
Old Apr 28, 2011 | 02:54 PM
JT FRC 00's Avatar
JT FRC 00
Default Meth injection
Im curious as well on using methanol injection. Don't mean to hijack by any means just wondering on the jetting size and if the vette needs to be tuned for it. Have the A&A supercharger ordered already and plan on having it installed next week. Not wanting it for any more power just for insurance mostly, but if it helps than that's a plus for sure! Just want to be safe with the Texas heat around the corner. Any input would be grateful.
Old Apr 28, 2011 | 03:05 PM
blownnastyc5's Avatar
blownnastyc5
The best way is to install it before the Intake Air Temp sensor so it can be tuned in that table to add timing when the temp drops from the spray. Then if something goes wrong it’s a catch net to keep bad from happening.... I would recommend tuning for it if utilized, other wise you may actually lose power. It doesn’t have to be a meth dependent tune if installed and tuned as I suggested, but at least taking full advantage of it when it is. Call and talk with a reputable meth/alcohol system company, they can better tell you what you need for your boost level and set-up.
Old Apr 29, 2011 | 10:07 AM
JT FRC 00's Avatar
JT FRC 00
That's what I needed to hear, before the AIT sensor. Wasn't sure about how to go about the safety part other than adding some safety parts along with the meth/water kit. Makes sense to use what you have on the car along with something else if need or wanting too. I talk to a rep at AEM on there kit, I know there pump is the new version that doesn't pulse but they could really advice me on the best location. I'll get with my tuner today and get things lined out. Thanks for the help
Old May 1, 2011 | 03:34 PM
robert miller's Avatar
robert miller
Originally Posted by Milan
1) Before the TB
But one Gallon in less than a month.
Old May 1, 2011 | 03:36 PM
JustinStrife's Avatar
JustinStrife
1) Before the TB
with all 3 points
Old May 1, 2011 | 09:12 PM
tony75A's Avatar
tony75A
I was looking at the remote reservoir but I'm scared it could fill the passenger compartment with flammable liquid if I get hit. Could be a bad combination with positive wires from the trunk mounted battery.
I hear you use winter blend washer solvent in the ww tank that way you can still clean the bug guts off
Old May 1, 2011 | 09:27 PM
Milan's Avatar
Milan
I used -20* F for awhile. Just recently switched to 50/50
Old May 1, 2011 | 10:05 PM
firefighter813x's Avatar
firefighter813x
Noticeable difference?
Old May 1, 2011 | 10:29 PM
corvette8189's Avatar
corvette8189
alky control kit, install how it says, use ww reservoir, run 100% meth, depends on how many nozzles and stuff but sounds like u would use less than a gallon a month.
Old May 1, 2011 | 11:18 PM
Milan's Avatar
Milan
Not sure yet because I'm waiting on my new rear tires to arrive
Old May 2, 2011 | 11:00 AM
416 Rigby's Avatar
416 Rigby
Default False economy--
Don't think I would run some unknown Big Box bug squirt in my engine. If one is at all considering the "meth" in their tune, consistancy of the fluid used could be very important.
With Shell and Cheveron near $4 here in Tucson the price of the real deal meth aint much.
To Info from those using meth injection
