I need to know F.I. Guy's Step inside
ISIS SUCKS FAT CHOAD
Ok, to hell with MSD plug wires. What else are you guy's running?
part numbers and or links?
I run MSD's, but have to meter them every time I remove and reinstall them because they break. I bought a second set to replace each one as it goes bad.
My next purchase will be the GMPP (GM performance parts) wires. Good wires and inexpensive.
I've also always liked the Taylor wires due to their nice boots
Well, the reason I'm asking is because I absolutely have to replace the MSD wires that are on the car due to them litterally falling apart when I removed them. I was as gentle with them as I could be. I had a friend who recommended taylor as well. 8mm or 10mm wire????
http://www.taylorvertex.com/Products/index.cgi/main3
I thought i read a post on here (years ago), and the resistence/quality of the stock wires were better than the GMPP wires.... Just sayin.
Taylors have the same problem, i bought 2 boxes and replaced them as i went... I now have the stockers back on...
John
John
2017 C5 of the Year Finalist
St. Jude Donor '08
I'm running Granatelli spark plug wires on both my cars. They have like a 2 on the resistance. I checked them out with a meter, and it's true. I too got tired of the MSD breaking...
Had nothing but problems with any factory gm truck or car wire. Nothing BUT problems. Wires are a route cause to so many peoples problems. I have had good results with MSD's, although I have gone through a couple of failures, I personally run taylor 10mm custom fit to length wires on my white car. Would love to know the actual part number myself but, I have no idea....it's been a while.
