nitrous guys
Old May 3, 2011 | 01:53 AM
Badd LS6's Avatar
Badd LS6
Default nitrous guys
any vette guys on here ever have a bad experience with your vettes on nitrous??
Old May 3, 2011 | 01:21 PM
Badd LS6's Avatar
Badd LS6
for once it's a GOOD thing a thread is getting no responses haha
Old May 3, 2011 | 01:42 PM
HP_Addict's Avatar
HP_Addict
People don't talk about the bad things. They try to forget them. Nitrous backfires occur. Intakes turn in to small bits. It happens. Part of playing with nitrous. Its happened to me, it happened to my friends. Its a gamble. You might spray the car 10 times or 1000 times, but the possibility always exists.
Old May 3, 2011 | 01:51 PM
Sea Five's Avatar
Sea Five
however, My ls1 GTO and my LS1 C5 respond very well to the nitrous. but I am overly cautious with safety features in my kits, rebuild solenoids regularly and run a wideband.
Old May 3, 2011 | 02:05 PM
Badd LS6's Avatar
Badd LS6
how regularly do you rebuild your solenoids??
i have a window switch,WOT,FPSS,,lean shutdown,wideband..car is being tuned thursday for the nitrous and i plan on hitting the track the next day for the first time using N20. any other tips of safety you recommend?
Old May 3, 2011 | 03:05 PM
SargeZ06's Avatar
SargeZ06
Do not spray below 3000rpm. I personally have my window switch set for 4000 in 1st gear and 3400 for 2nd -4th. Do not spray past 4th gear. Set window switch a few hundred lower than your rev limiter.
Read your plugs to tune it. Don't rely on the wideband for tuning. It will help if something goes really wrong for lean/rich shutoff but that's it.
Old May 3, 2011 | 03:10 PM
Badd LS6's Avatar
Badd LS6
im gonna have first gear locked out..and the window set at 3000-6200..i have no idea how to read plugs..i don't have a hand-held, i'm having it professionally dyno tuned this thursday
Old May 3, 2011 | 03:39 PM
SargeZ06's Avatar
SargeZ06
What size shot are you going with? You need the correct plugs for whatever size shot you use.
Old May 3, 2011 | 03:48 PM
nyg215's Avatar
nyg215
why not spray in 5th gear? i have 4.10s so it would be hard to not ever spray in 5th
Old May 3, 2011 | 03:51 PM
SargeZ06's Avatar
SargeZ06
4.10s is a different story. 3.42, 3.15, or 2.73s would put too much lug on the motor and could cause a backfire.
Old May 3, 2011 | 03:52 PM
nyg215's Avatar
nyg215
ok thanks for the clarification...almost crapped my self since i have already sprayed in 5th
Old May 3, 2011 | 04:00 PM
SargeZ06's Avatar
SargeZ06
You still need to beware of spraying to long in any one gear. If 5th lasts longer than 3-4 seconds I would avoid it. Sustained spraying in any gear is bad.
Old May 3, 2011 | 07:32 PM
Badd LS6's Avatar
Badd LS6
i have NGK TR6s with the proper gap..put in when the kit went in..i been running on them for a couple weeks now..i plan on starting off with a 100 shot..im having my tuner take out the proper degrees of timing for a 100shot..and when the new version of the lingenfelter controller comes out i'm gonna bump to a 150 shot and have my tuner put back in the timing and than adjust the timing retard on the controller..
Old May 4, 2011 | 09:08 PM
Nate B's Avatar
Nate B
I would run NGK br7ef if I were you. Get on the nitrous section of ls1 tech, lots of really good info in the stickies.
Old May 5, 2011 | 04:38 AM
Badd LS6's Avatar
Badd LS6
i went through the stickies lil while back.. are the TR6s not a good plug to go with??
Old May 5, 2011 | 06:47 AM
SargeZ06's Avatar
SargeZ06
Not safely. I run the BR7EF. They will be good up to a 200 shot.
Old May 7, 2011 | 12:04 PM
Sea Five's Avatar
Sea Five
yep, the TR6 is a projected tip plug, essentially acting like a blow torch tio the top of your pistons if temps get hot enough. its a safe plug for a small shot but i would go with the BR7EF for 100+ shots. make sure your timing pull coinsides with your nitrous shot, or about 2 degrees per 50 hp on stock timing is my rule of thumb, and is pretty "safe".
100 shot
window switch 3k+ -6000 (before the limiter)
you CAN spray off the line if your clutch holds it
pull 4 degrees of timing to start
run a BR7EF plug
check the jetting with a wideband
track tune by shutting down right after a quick nitrous gear pass pull a plug and read the plug reading sticky to go from there. timing marks are very apparent on new plugs, and a wideband should have you really close on the fueling. always make sure you have consistant nitrous pressure and never let that be a variable when jetting. (low pressure =rich, dont jet down if your bottle is low...when you re fill, it will be lean)
To nitrous guys
