need pics for ideas
Old May 4, 2011 | 10:40 PM
01z0666's Avatar
01z0666
Default need pics for ideas
did the dewitts 2" cut down, trying to see what others have done for radiator brackets, I cut my factory one as a temp and deffinitely dont want that...its fugly as shyt
Old May 4, 2011 | 11:01 PM
Z06supercharged's Avatar
Z06supercharged
I dont use anything and it stays put just fine. The upper hose keeps it steady on drivers side and rigid condenser lines keeps it steady on passenger side. I used rubber edge pieces on top plate that was included in S/C kit and it holds tightly against both sides of the taller top Dewitt's side framing I guess its called so it all stays nice and tight.
I also have dual Spal fans and custom Dewitt's shroud so I have plenty of clearance between down tube and fan shroud so even if radiator moved back and forth a little it still doesnt hit against the down tube. The factory shroud was way too close for my liking and always rubbing the down tube.
Old May 5, 2011 | 12:13 AM
01z0666's Avatar
01z0666
well this is for my ttix kit since I'm running a 4" intake pipe tio the tb
Old May 5, 2011 | 12:26 PM
95wht6spd's Avatar
95wht6spd
I have the same fan/rad set up but not installed yet. How is the cooling, what temps do you see?
Old May 5, 2011 | 12:56 PM
TheCartel's Avatar
TheCartel
Sure here you go. I fabbed this real quick out of some spare 16 guage steel. Works great.
Mock up test fitting.
and here it is coated and done.
Old May 5, 2011 | 01:16 PM
01z0666's Avatar
01z0666
no temps yet, just put it in last night but I also have a meziere wp with 160 stat
Old May 5, 2011 | 01:18 PM
01z0666's Avatar
01z0666
thats not bad...I guess I'll find some steele today and start playing
Old May 5, 2011 | 02:21 PM
Z06supercharged
To be quite honest I see the same coolant temps as I did with stock radiator and same fan settings. I didnt get the Dewitt's because of cooling issues but I think because its thicker and shorter it cools the same. I see 185-190 in stop and go in 75-80 degrees ambient (my high fan is set to come on at 192 and fans off at 183). On the freeway I see 180-183 in same ambient temps. I never run hotter than 192 coolant temps just driving normally. When in boost for 10-20 seconds coolant temps will go to 205 max but they did also with stock radiator so no change there either..
The thicker and shorter core IMHO cools the same as a stock taller thinner core. I see no difference I think because the 2" cut down holds the same amount of water as the stock one does but less efficient because of the thicker core.
To need pics for ideas
