lets talk boost (esc kit)
Old May 8, 2011 | 09:11 PM
everydaydriverz's Avatar
everydaydriverz
Default lets talk boost (esc kit)
i have a 383 with 9.5 to 1 comp. ls6 heads fully ported, 224 228 600 600 lift cam ect...
also i have a 8 rib convesion on it with a Innovator west balancer and a 3.0 pully the kit is a novi 2000 from ecs i have very little belt slip if any. the 1 to 2 shift the boost is bouncing around 5 or 7 pounds and when i get it in high gear it hits 9 psi its not very steady and all over the place and seems really low for my setup. i made the same boost last sumer with out the Innovator west and 3.0. )i had a stock balancer and a 3.25 pully with a 6 rib also theres no loose hose or leaks ect
thanks for any help or ideals
Old May 9, 2011 | 11:10 AM
everydaydriverz
anyone got any advice or have seen this?
Old May 9, 2011 | 01:26 PM
robert miller's Avatar
robert miller
If you dont have a leak then it looks like belt. I had belt slip with only the 8 rib set up on mine. I then went to flip drive and the from a 3.25 pulley to a 3.0 pulley and making alot more boost and H.P with no belt slip now with just over 18 on the boost gauge. Robert Give BLOWNBLUEZ06 a p.m. on your post and see what he tells you..
Old May 9, 2011 | 03:49 PM
fsuforever's Avatar
fsuforever
Ya I had similar with my 8 rib setup ecs kit,I was @ the tuner on thedyno& crunch time ,car wasntmaking over 8lb of boost & iafter numerous calls. To chris & doug we realized the tensioner was sittingaround 2.00 pm on the clock, changed the idler pulley to another slot & gained 200rwhp ,not saying this your issue butthis was an issuei had @1 time & was fixed by an idler pulley slot swap,this will help allow more belt wrap around the bottom of the balancer,if u don't have the tensioner wrench byall means get 1, u can clamp it to ur cradle. Take care of buisiness & then tighten the top tensioner before letting the clamp loose on the bottom tensioner,this will help hold the bottom tensioner all the way out & that's what u want with the ecs kit,goodluck with it,jd
Old May 9, 2011 | 08:55 PM
95vettski's Avatar
95vettski
Something doesn't sound right! With that pulley and the 8" crank you should be making over 15lbs of boost! Make sure your pulleys are aligned properly and as mentioned the tensioner next to the crank needs to be between the 12-1 oclock position...you may need a shorter belt.
Old May 10, 2011 | 01:23 AM
everydaydriverz
this is what i was thinking also my belt is super tight and does not slip we checked this my looking back at the log and watching the volts they looked alright i don't know whats going on the this thing......could my head unit be messed up what happens when they go out or break or need a rebuild? thanks
Old May 10, 2011 | 08:48 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
That's what it sounds like to me.
The belt can be very tight, but if the tensioner is not fully opened when the belt stretches during a WOT pull it will bottom out the tesioner and cause the boost to drop.
You should be making a lot more boost then you are, so something is definitely off. Feel free to call the shop if we can help you with anything.
Old May 10, 2011 | 09:35 AM
fsuforever's Avatar
fsuforever
Exactly,I'm just an old dumb welder ,who's inhaled 1too many stick rods :don't pay any attention to me
Old May 10, 2011 | 02:33 PM
everydaydriverz
ok thanks for the info i will check it out and post my update
Old May 10, 2011 | 03:48 PM
p1bz's Avatar
p1bz
Make sure the BOV is sealing under boost.
To lets talk boost (esc kit)
