A&A Kit: Need Power Steering Bracket?
Old May 10, 2011 | 01:40 PM
4SFED Z's Avatar
4SFED Z
Default A&A Kit: Need Power Steering Bracket?
With the A&A kit, do you need the 2003-up power steering bracket? Mine is an 2002
Old May 10, 2011 | 01:44 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Best to have the newer one for sure. They're only ~85 shipped.
I won't install a supercharger without it. It's just not worth the savings.
Google GM part# 12578068
Old May 10, 2011 | 01:47 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default mmmmm
Not sure I heard of that before - better check mine!!
Old May 10, 2011 | 01:52 PM
BLOWNBLUEZ06
If yours looks like the one on the left with the open section nearest to the idler pulley on the bottom, it's the bad one.
Old May 10, 2011 | 01:53 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Bret,
Guess I could search, is there an issue with the earlier brackets? Mine is also an '02..
Thanks!
Edit. seen your post.. thanks.
Old May 10, 2011 | 03:58 PM
Slow Z06's Avatar
Slow Z06
You are doing the YSI arent you? Might want to ask about any YSI specific parts that would be good to install the first time.
Old May 10, 2011 | 03:59 PM
corvette8189's Avatar
corvette8189
they still could break best way is to use the ecs idler......oh and i got one for sale http://forums.corvetteforum.com/c5-f...xed-idler.html
Old May 10, 2011 | 04:27 PM
4SFED Z's Avatar
4SFED Z
V2-Si
Old May 10, 2011 | 04:43 PM
corvette8189
Originally Posted by NastyZ
V2-Si
get the ysi youll want it sooner or later
Old May 10, 2011 | 05:48 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Old May 10, 2011 | 06:02 PM
MyEBc5Z's Avatar
MyEBc5Z
I and several other didn't get the newer ones and we haven't had any problems.....yet. When I make more power I will be sure to change it
Old May 10, 2011 | 06:54 PM
1redz06's Avatar
1redz06
Just ordered mine today
Old May 10, 2011 | 07:20 PM
BLOWNBLUEZ06
Originally Posted by Get Bit
Bret,
Thanks!
The earlier brackets are prone to breaking much easier than the newer ones. It didn't happen to me for quite a while and then it left me stranded. 200.00 tow due to a 80.00 part is the definition of suck!!
Old May 10, 2011 | 08:54 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Understand that! Will have to get one ordered.
Old May 10, 2011 | 10:43 PM
4SFED Z's Avatar
4SFED Z
I got one today. Gm parts direct. Was about 70 shipped. Now I have a piece of mind. No ysi for me. It will be healthy enough
Old May 11, 2011 | 01:37 AM
corvette8189
one of yall need to buy my ecs idler, and not have to worry about anything
Old May 11, 2011 | 02:11 AM
JustinStrife's Avatar
JustinStrife
To A&A Kit: Need Power Steering Bracket?
Old May 11, 2011 | 07:06 AM
SLVRCPE's Avatar
SLVRCPE
I changed mine to the new style during the install. If you are doing the install yourself be prepared for some cussing, and you might want to get a new PS pulley just in case you break yours. Like others have said, I changed mine "just in case" I am not sure what else could be damaged if the thing broke at high rpm or MPH..
Old May 11, 2011 | 07:15 AM
4SFED Z's Avatar
4SFED Z
Its ordered and will be changed
Good thing is that I posted up and its obvious some people didnt know this...
Old May 11, 2011 | 07:29 AM
SLVRCPE's Avatar
SLVRCPE
A&A calls this out in the install instructions. This is one thing that pushed me to do the install myself. I called several shops for install quotes and none of them mentioned this replacement.
As a side note, I talked to one of the A@A mechanics to nail down a belt issue. During the conversation he did mention he has seen more of these early brackets broken lately.
