Question about boost?
Old May 18, 2011 | 11:41 AM
SDLS1Rider's Avatar
SDLS1Rider
Default Question about boost?
I keep reading posts that say any boost below 7 psi is simply not worth it?
I have a high compression engine (11:1). To add a supercharger with this compressionwould limit the amount of boost I can run (6 psi max.?). But most people from the FI world say this is a waste. While I realize that more boost makes more power, I actually have an upper limit of 550 rwhp I would run, but I would be happy with anything over 500. Currently the engine does 438 rwhp. Lets say it will do 400 rwhp once cam and exhaust changes are made before the blower is installed. Could the supercharger install make 500+ rwhp?
So would the S/C experts consider an 11:1 compression engine running at 6 psi a diminishing return?
Old May 18, 2011 | 11:57 AM
Milan's Avatar
Milan
It has nothing to do with psi. Psi is a term people use when they don't know what they are talking about.
7 psi on a Vortech S-trim is going to be completely different than 7 psi on a F1 Procharger
Is your 11:1 compression built? If you have forged internals you can honestly make a lot more than 500 whp even if you have high CR, I think you will unfortunately be limited to the crap 91 octane you get in CA unless you can find some E85 or race gas.
Old May 18, 2011 | 12:01 PM
ysb02's Avatar
ysb02
Get a si-trim kit and run 6 psi = 550 rwhp. There's plenty of people here running 11+ with FI.
Old May 18, 2011 | 12:03 PM
SDLS1Rider's Avatar
SDLS1Rider
Only the heads were built up, and they are on the car. All pistons and the rotating assembly are stock.
Old May 18, 2011 | 12:28 PM
4SFED Z's Avatar
4SFED Z
Old May 18, 2011 | 12:36 PM
C5sleeper's Avatar
C5sleeper
Keep it under 550 rwhp and your should be fine regardlesss..
Like stated before it isnt Lbs of boost, its more tune than Lbs of boost
Old May 18, 2011 | 01:42 PM
95BlueBomber's Avatar
95BlueBomber
Any boost is worth it!
Old May 18, 2011 | 02:08 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Hello, I was in the same situation as you almost a year ago. To save on time I have attached my old thread with the results. IMO it will be a matter of time of when the stock bottom will let go.
http://forums.corvetteforum.com/c5-f...-na-to-fi.html
Old May 18, 2011 | 03:21 PM
SDLS1Rider's Avatar
SDLS1Rider
Thanks for the link. I did notice that you had much more radical mods than I did. Your power levels were coming in almost 100HP more than what I am looking for. Can I ask how many miles the engine had on it?
I have been thinking of installing forged (dish) pistons. But I can just image what that would do to my labor costs? Anybody know what that would cost?
Old May 18, 2011 | 04:52 PM
DNAST1's Avatar
DNAST1
My engine on had 18.5K on her when she let go
Old May 18, 2011 | 05:08 PM
SDLS1Rider's Avatar
SDLS1Rider
That's less than my 33K.
Old May 18, 2011 | 08:14 PM
Blow Torch's Avatar
Blow Torch
Im around 10.9cr and running 10 1/2lbs of boost for around 700rwhp. The high compression makes it extremly "peppy" when you're not in boost (which is most of the tiime unless you race )
It will eventually let go, but I'm running it really rich with lots of Meth and and its making some good power now
Old May 18, 2011 | 11:23 PM
SDLS1Rider's Avatar
SDLS1Rider
When does the boost come on? Are set up a specific way to keep the boost off until a higher rpm?
Old May 19, 2011 | 08:34 AM
Blow Torch's Avatar
Blow Torch
Depends on how I accelerate. I have a stall, so if I floor it, I am in boost instantly, since the stall lets it flash to 3000+, and vacuum drops to zero. If I ease slowly into it, it comes on more gradually, just like any other system.
I have a 3.7" pulley, so it gets there quick. I'm not set up any differently than a lower compression system, except I have to run less timing (17*) lots of meth, limit my max rpm to 6200 (rod bolts) and I will obviously not go any higher with my boost.
Old May 19, 2011 | 02:24 PM
SDLS1Rider's Avatar
SDLS1Rider
I noticed you still have 3.42 gears so I can't tell if you are set up for drag racing or road racing. I spend most of my recreational driving canyon carving. I've seen extended high rpm driving. Sure the engine temperatures would increase, I would include a high capacity radiator if I installed a S/C. But I'm still wondering how canyon carving would effect the longevity of my engine, or is it all just a matter of time?. Perhaps that should be the subject of another thread.
To Question about boost?
