need help with timing tuner!!!
Old May 30, 2011 | 10:38 PM
livetocruise's Avatar
livetocruise
Default need help with timing tuner!!!
I have a "timing tuner" on my LS mainly used to control/adjust timing when using nitrous also to utilize the window switch integrated into the box for controlling activation of the system. My problem is that I have lost the manual that came with the box, and I want to adjust my settings, and I don't have any way to see what ***** control what!! Do you any of you either have, or have access to the installation manual with the box so that I can see what I'm adjusting?? Thank you in advance for your time!!
Old May 30, 2011 | 10:58 PM
robert miller's Avatar
robert miller
Should be able to get on the seller web site and look are email them to email are fax you a set of what you are in need of.
Old Jun 5, 2011 | 11:23 AM
syke410's Avatar
syke410
try this:
http://fullthrottletech.com/showthread.php?t=907
great little website, bob bailey the designer really stays on top of things!
To need help with timing tuner!!!
