another spark plug question
Old May 30, 2011 | 11:27 PM
jetning's Avatar
jetning
Default another spark plug question
I was using NGK TR6 with 125 shot of nitrous, but just bumped it up to 150. Do I keep the same plug or go up to thr TR7s? What's the gap for the TR7s if that's what I need? Thanks
Old May 31, 2011 | 11:04 AM
98vettedave's Avatar
98vettedave
Run the TR7's @.035 and pull a minimum of 5* timing to be safe. The TR6's have the extended tip...not recommended for nitrous applications.
Old May 31, 2011 | 05:03 PM
nyg215's Avatar
nyg215
I have been running the TR6's for about 6 months and haven't had a problem...
Old May 31, 2011 | 06:29 PM
98vettedave
Good for you! The proper plugs to run with a 150/175 shot are TR7's. No debate here...give the experts a call...Harris Speed Works,Nitro Dave's or any other major nitrous parts supplier and ask then their opinion on running a projected plug tip (TR6's) while on nitrous.
Old May 31, 2011 | 10:22 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Getting away with it and it being a wise decision to do are 2 totally different things. Not trying to be a smart @ss, but trying to get my point across.
I learned the best way to choose a plug is to go with the coldest plug that doesn't cause you problems as opposed to the most aggressive plug you can get away with.
The non-projected tip #7 (3346) are the way to go with any significant boost or nitrous with a #8 (1049) in the #7 cylinder position for good measure.
Old Jun 1, 2011 | 10:23 PM
joshtownsend's Avatar
joshtownsend
you mean NGK BR7ef
Old Jun 1, 2011 | 10:26 PM
BLOWNBLUEZ06
Originally Posted by joshtownsend
you mean ngk br7ef
ngk br7ef = ngk 3346
Old Jun 8, 2011 | 03:07 PM
nyg215's Avatar
nyg215
How does the car run with two different plugs?
Old Jun 8, 2011 | 03:43 PM
AZZ-KIKR's Avatar
AZZ-KIKR
Gives it a nice lopey sound.
Old Jun 8, 2011 | 05:44 PM
BLOWNBLUEZ06
It runs safer. This is only catering to high-boost motors that need to play it conservative with the hot #7 cylinder. It's a known fact that #7 is this way. I would run all 8's but they foul much more easily due to the lack of heat, so I keep one in #7 only and the rest get 7's.
Old Jun 8, 2011 | 06:05 PM
nyg215's Avatar
nyg215
OK, thanks for the info!! do you think i would need to put an 8 plug into #7 with a 150 shot? I just bought a set of 7's since i have been reading 7's are the way to go...
Old Jun 8, 2011 | 06:10 PM
BLOWNBLUEZ06
If you properly read your plugs using a magnifier and see any signs of detonation whatsoever on #7, then buy an 8 plug and stick it in there. I don't really think it's necessary on a 150 shot, but if you get froggy and jump to a 250, don't even bother asking.
Old Jun 8, 2011 | 06:56 PM
nyg215's Avatar
nyg215
Ok thanks!! i dont see 250 in my near future....maybe 175...
Old Jun 8, 2011 | 09:35 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Old Jun 8, 2011 | 09:50 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Hey Smartass.Don't be getting froggy till that knee heals.
Old Jun 8, 2011 | 10:26 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
The TR7s work quite well!!!
JB
To another spark plug question
