N2O for cooling?
Old Jun 16, 2011 | 06:02 PM
The Mountain Kat's Avatar
The Mountain Kat
Default N2O for cooling?
Have any of you here, with an InterCooler, used a small N2O bleed on the inlet to cool the air stream? I have seen H2O injection and Methanol done this way. I am thinking of using one of my own design micro-foggers with about a 0.012" jet spraying directly into the Inter-Cooler ingress. A simple thermostatic control switch would work and there shouldn't be enough N2O to raise the power output significantly. I think that the MAF would be able to register the change in Airflow well enough.
Any Pros/Cons?
Old Jun 16, 2011 | 11:52 PM
chevylad's Avatar
chevylad
I've seen different intercooler setups spray nitrous or CO2, just keep your intake away from what you spray. You can even buy "spray rings" or complete intercoolers with built in sprayers.
Old Jun 17, 2011 | 07:52 AM
chuntington101's Avatar
chuntington101
why not just spray a small shot, say 25bhp, into the intake as you would do a normal N2O shot. Even if its a wet shot you should still see much more than the 25bhp gains.
By the way you will want to mount the nozzel post intercooler. may as well get as much heat out of the air with the intercooler before you use the N2O.
Chris.
Old Jun 17, 2011 | 07:56 AM
chuntington101
Really dont see the point in these! Basicly you are using the N2O or CO2 to cool the intercooler. Ok in short bursts but to me just seem to be covering up an inefficet intercooler setup! also the time the exspanding gas will actually ahve in contact with the IC core will be VERY small, thus the thermal trashfer cant be that great. If you wanted to use compressed gas to cool the intake you could be better suing a chargecooler type setup and either using the gas to cool the water.
Chris.
Old Jun 17, 2011 | 09:05 AM
dizwiz24's Avatar
dizwiz24
Can use the nitrous on a window switch for starting line power (centrifugal blower), then let the blower take over at high rpms.
Old Jun 17, 2011 | 11:05 AM
The Mountain Kat
Interesting comments. Thanks to all.
Old Jun 17, 2011 | 12:27 PM
p1bz's Avatar
p1bz
If you are spraying outside the intercooler, it is too expensive, and if you are spraying in the tubing, nitrous burns very hot, it doesn't matter that it comes out of the bottle cold, that is a bad idea. What you are after is water/meth 50/50 mix, as the meth drops IAT's and the water lowers EGT's. The meth doesn't do much for in chamber cooling, but water does. Good luck. Steve
Old Jun 17, 2011 | 03:51 PM
dizwiz24's Avatar
dizwiz24
It only burns hot if it's lean bc you are only spraying nitrous.
If you are spraying it wet (w. Fuel) I can't imagine it'd be any hotter
Old Jun 18, 2011 | 01:33 PM
p1bz's Avatar
p1bz
Incorrect information. Please don't be guessing at the expense of other peoples engines.
Old Jun 18, 2011 | 06:47 PM
chevylad's Avatar
chevylad
Chris.
I've never tried this before, but I have seen the setup several times in drag racing cars. They only run very short burst of spray, of about 5 seconds. Do an internet search on "nitrous cooling intercooler." Some guys are claiming over 50hp from the effect. No, I'm sure it's not cheap, but that's how it is in open competition. C02 is not as expensive if you can keep the gas away from the intake.
I didn't realize there are a lot of people making these kits until I did a search, so a lot of people out there must feel it works.
Old Jun 18, 2011 | 09:44 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Fairly common on diesels.
Old Jun 20, 2011 | 08:35 AM
chuntington101
Im not saying it dosen't work! when you think about it its pretty hard for it not to work! lol.
Take C02. You store it at 4500psi at room temp and then release it. Its going to be VERY cold! when that frezzing cold gas hits the IC its going to reduce temps.
my point was its not the best solution. If you are on the street then you are only going to get a few WOT hits before the bottle(s) run dry. and then you are left with the same high IATs that lead you to fit the kit in the first place. you would be better of fitting a better design intercooler or even going A2W to help with the temps. At least if you inject n2o directly into the intake pipework you are not only seeing ALL the cooling advantage (i wonder just how effective these sprayers are at reducing IC temps) but also the added oxygen to burn extra fuel. its fairly regular to seepower increase by more than 150% the sze of the N2O shot on FI cars (eg you spray a 50bhp shot and you see 75bhp increase in power). this extra 50% is thanks thanks to the cooling effect the N2O has.
This is juts my opinion of course.
Chris.
To N2O for cooling?
