Backpressure
Old Jun 21, 2011 | 10:05 PM
Dave concrete's Avatar
Dave concrete
Default Backpressure
Got into a conversation today with a friend on backpressure since he is having work done on his brand new 911 turbo S. He got me thinking, Is there enough backpressure on my car I have a Novi set up, headers, hi-flows into Borla straight pipes.
Old Jun 21, 2011 | 10:09 PM
robert miller's Avatar
robert miller
With the high flow cats you have to have, dont see any way you dont. I just cut my high flow cats out and sold them. Robert
Old Jun 22, 2011 | 06:58 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Race your friend and that should answer your question.
Old Jun 22, 2011 | 07:51 PM
Dave concrete
Well thats fine and dandy but really doesn't answer the question. Odds are I'm thinking he will take me. MT has that car under 3 seconds to 60 with 550hp he is now going to be in the 650area.
Old Jun 22, 2011 | 08:14 PM
BLOWNBLUEZ06
Just being facetious. My way of saying the better our cars breathe with F/I, the better off you are. Not sure if you recall my 2" header and intake upgrade thread, but I picked up tons of power from 4500 up. I don't recall your entire setup, but I'm sure if the race is long enough you will have a good race on your hands.
Old Jun 23, 2011 | 02:43 PM
stevieturbo's Avatar
stevieturbo
Why on earth would you want backpressure ? That's just stupid.
Old Jun 23, 2011 | 04:04 PM
95BlueBomber's Avatar
95BlueBomber
I guess technically you have "backpressure" when you are in boost. The pressure in the intake is due to air being forced into the engine that it cannot immediately digest and release through the exhaust. With a supercharger you are going to see backpressure no matter what. Most times when you start opening things up its going to relieve some of the pressure (boost levels go down) and the power level rises, its because you have increased the efficiency of the engine.
Old Jun 24, 2011 | 08:19 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
That was funny..
Dave, less is better, as already stated.
Old Jun 24, 2011 | 06:21 PM
Dave concrete
Its not that I was looking for it he mentioned on his car he needed it so just got me thinking.
Old Jun 24, 2011 | 06:54 PM
Carlmc1's Avatar
Carlmc1
It could be true (for example) if he didnt have enough backpressue it could push the powerband up. It would make more power but the usable powerband would be smaller but generally less backpressure is better
Carl
Edit- I'm referring to backpressure created by the turbos. A turbo with a large turbine housing and/or large turbine wheel can dramatically change the powerband. It has more to do with properly sized turbos but its also back pressure and its probably what he was trying to say.
Carl
Old Jun 24, 2011 | 07:31 PM
stevieturbo
No properly tuned car needs it or wants it.. He's just stupid.
An engine is little different to us. they both consume air and expel it.
Strangling an engines breathing is little different than strangling yourself
To Backpressure
