97-00 Air Speed Sensor delete?
Old Jun 27, 2011 | 12:38 AM
reactor2's Avatar
reactor2
Default 97-00 Air Speed Sensor delete?
What does the air speed sensor (located right in front of the TB) actually do? Is it safe to leave this off? I have a new shiny A&A polished aluminum tube and I don't want to drill a hole in it to mount this goofy little sensor.
Old Jun 27, 2011 | 09:26 AM
99MALLETT396's Avatar
99MALLETT396
That's an intake air temp sensor not air speed sensor, but you have to have the sensor cause that will enable the PCM to pull some timing if the air charge gets to hot. Some one correct me if i am wrong please.
Old Jun 27, 2011 | 12:13 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
If you are speaking of the IAT sensor (intake air temp), you can mount it on the bottom side of the pipe so that it's more out of site.
Old Jun 27, 2011 | 12:39 PM
Its Bruce's Avatar
Its Bruce
Air speed sensor? Does it look like this?
Old Jun 27, 2011 | 12:42 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Just get the LS6 MAF Sensor and the IAT is built in. That way you will not have to drill the intake tube.
Old Jun 27, 2011 | 01:43 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Old Jun 27, 2011 | 04:24 PM
Its Bruce's Avatar
Its Bruce
If you plan to use meth in the future, I suggest keeping them separate.
Old Jun 27, 2011 | 08:23 PM
JT FRC 00's Avatar
JT FRC 00
Default Ls6
Depends on what kind of power you want to make. If you don't have any plans on using meth get the LS6 MAF, it's bigger than a LS1 MAF I believe. ( 85mm ) Plus it's a much cleaner look. If meth is wanted or needed down the road you can always put the other one back on and drill your hole then. Just an option.
Old Jun 28, 2011 | 01:13 AM
reactor2's Avatar
reactor2
Oh, yeah, air temp sensor not air speed sensor.
To 97-00 Air Speed Sensor delete?
