Valve Springs
Old Jun 27, 2011 | 05:27 PM
phil hunter's Avatar
phil hunter
Default Valve Springs
Just got my car back last week from having an A & A Si kit installed and the car runs really well, although I must say that I am a little disappointed with the power it made on the dyno. Car made 474 hp before encountering valve float. My tuner is recommending I install the 2004 ZO6 valve springs on the motor, which I believe are yellow and carry GM part #12586484. They are certainly cheap enough, and the install cost isn't bad, so I was wondering if anyone here is running them on their LS1 and how much rpm and horsepower they gained. If not these springs which ones would you recommend for my combination?
Phil
Old Jun 27, 2011 | 08:48 PM
1320IN9's Avatar
1320IN9
get some patriot dual springs, part# 8501 and you'll be good to go
Old Jun 27, 2011 | 08:56 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Which pulley did you go with?
Old Jun 27, 2011 | 08:59 PM
JLayer's Avatar
JLayer
Pass on the gm springs...put some PAC 1218's (single .600 max) or 1215's (double .650 max) on them. I think I paid $140 plus shipping.
Had the same issue on mine. Put 491 down....swapped out the springs with the 1218's and made 578 afterward.
Old Jun 27, 2011 | 11:30 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
The horsepower is directly proportional to RPM (Tq*RPM/5252), so don't worry. Replace the springs and the numbers will follow. I'm with the rest of the crowd. The GM springs are insufficient for your supercharged application. Patriot duals are probably the most popular and the best bang for the buck IMO.
Old Jun 28, 2011 | 01:08 AM
Chris Stewart's Avatar
Chris Stewart
I have some used springs in good condition if you're interested.
2003 LS6 springs, 30K miles
$50 shipped
Comp Cams 918 springs, no miles just dyno time
$100 shipped
Old Jun 28, 2011 | 11:12 AM
phil hunter
I'm running the stock pulley. It is pinned. I am somewhat surprised that the valves started to float at 5200 rpm, given that the motor has less than 14,000 miles on it.
Thanks for the tips guys.
Not really interested in used springs, but thanks for the offer. Only question left now, is whether to go with the 1218's or the 1215's.
Phil
Old Jun 28, 2011 | 12:43 PM
BLOWNBLUEZ06
Not sure why you're surprised considering that a mere 10psi of boost will reduce your effective intake valve spring pressure by ~28psi.
Old Jun 28, 2011 | 03:29 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
$50 shipped
$100 shipped
OP, I would go with the 918s, great price.
Old Jun 28, 2011 | 08:39 PM
phil hunter
10 psi of boost drops effective spring pressure by 28 lbs? First I've heard of that. The stockers are only 76# closed and 220# open so that is a big impact! It would certainly explain things. Guess, I better get those springs pretty soon.
Blitzkrieg,
OK, I'm interested in the 918's but am wondering, why did you remove them from the car after the dyno runs?
Also, anyone else running these springs? Are you happy with them?
Phil
Old Jun 28, 2011 | 09:57 PM
Chris Stewart
I got a bigger cam about .610 lift, and these 918's don't work. Going out to pull them off the heads right now, and will take some pics.
Old Jun 28, 2011 | 10:51 PM
BLOWNBLUEZ06
10 pounds per square inch applied across the back side of a 2.02" valve in, which drops the effective pressure by the amount of pressure (boost) applied the the back of that valve. Once the valve opens, the pressure is allowed to equalize some. Same concept as boost-referenced fuel. You always take the intake pressure and subtract it from the fuel pressure to get your effective pressure. If you have 43psi fuel pressure and 43 psi boost, when you open the injector, 0 fuel will flow.
Old Jun 29, 2011 | 02:51 AM
Chris Stewart
Here are the 918s before I pulled them. Right now they're in a bag with retainer caps and valve locks. They appear to be compatible with stock seals, so those don't have to be changed. Let me know if you want them.
Old Jun 29, 2011 | 08:16 PM
phil hunter
Hi Chris,
OK, I'll take them. Not clear what I'm buying though. Are you talking the springs, retainer caps, and clips for $100, or just the springs? Did some research and they are indeed compatible with stock valve stem seals and retainers.
Phil
To Valve Springs
