Engine oil or self-contained
Old Jul 4, 2011 | 10:42 PM
had2have-it's Avatar
had2have-it
Default Engine oil or self-contained
Doing a little FI research, on a daily driven no meth, pump gas, centri, what are the pros and cons for self contained lube or engine plumbed oil? thanks
Old Jul 5, 2011 | 01:34 PM
mmartinez's Avatar
mmartinez
Pros are no oil lines and having to drill and tap your oil pan, cons are having to change super charger oil at regular intervels.
Old Jul 5, 2011 | 03:58 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Performance wise, they are the same.
Old Jul 5, 2011 | 06:48 PM
zeevette's Avatar
zeevette
I think the biggest "pro" to having a self-contained head unit is the isolation it gives you from contamination in engine oil. If small bits of crap get in your crankcase, they won't get to your SC.
Old Jul 5, 2011 | 07:11 PM
Warp Factor's Avatar
Warp Factor
If this is a concern, put a filter on the supercharger oil supply line.
There have been a few cases of oil lines getting ripped off when a drive belt breaks. On the flip side, self-contained superchargers seem to show more goop and debris when taken apart, judging from pictures posted here.
Old Jul 5, 2011 | 08:22 PM
Z06supercharged's Avatar
Z06supercharged
I have a belt guard between the crank pulley and oil line so if belt breaks it will not whip around and take out my oil line. I also have never seen any crap in my little inline mesh filter at the head unit either in 15K miles. I did however have the head unit eat a bearing race up and all the little pieces went down the drain line into the oil pan. No harm done I guess as the filter or pickup screen would catch any of it before circulating it back though..
Old Jul 5, 2011 | 08:27 PM
turbocrazy's Avatar
turbocrazy
I have a self contained and I think it is more for the piece of mind than anything else, not to mention I think the upgrade is only a couple hundred from A&A. Good luck
Old Jul 5, 2011 | 08:44 PM
phil hunter's Avatar
phil hunter
I went with the self contained unit because I didn't like the idea of dirty engine oil circulating through the supercharger. These units only move air, so it should be very difficult for the oil in them to get contaminated, so it should stay clean for quite a while.
Phil
Old Jul 6, 2011 | 10:54 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I had lots of problems with a Novi 1200 engine oil fed backing up and leaking oil into the compressor side. Switched to a 1500 self contained and no issues since. The only way I'd go back to engine oil is if I upgrade to a Ysi and have no other choice.
Old Jul 6, 2011 | 06:34 PM
JT FRC 00's Avatar
JT FRC 00
Default Self contained
Biggest reason I wanted a self contained unit is the oil is made for that supercharger. That unit cranks out some high RPM's during use. The motor alone is breaking down your oil, didn't want anything else helping! If I upgrade then I may need to tap the pan down the road but not till then.
Old Jul 6, 2011 | 07:42 PM
Dave concrete's Avatar
Dave concrete
I wonder if the engineers at Paxton thought of that
You could argue and say that the internals in a self contained unit are breaking down and over time their constantly recirculating. Paxton is no small potatoes in the FI world and all the years on this forum I don't recall to much issues pointing at failure from crankase oil.
Old Jul 7, 2011 | 12:28 AM
Z06ster's Avatar
Z06ster
So far, I have seen a few posts in favor of self contained. I have had both. No offense intended to anyone in favor of self contained but I think self contained units are overrated. I can tell you it doesn't help the supercharger head unit live longer. I had a self contained P1SC Procharger and after a mere 6 years/30K miles use, it developed a bad leak that even Procharger couldn't fix right the first time when it was sent to them. Plus, they're a pain to change the oil. Please correct me if I am in error but with an engine oil fed head unit, you have one less oil change to do!
Old Jul 10, 2011 | 12:47 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I use the Self Contained Oiling is all of my builds. Simplier system and the oil change procedure is easy.
Old Jul 10, 2011 | 03:35 PM
Warp Factor
Would wear debris build up faster in 6(?) ounces of blower oil, versus 6 quarts of filtered engine oil?
Engine oils hold up well enough for superbike transmissions and wet clutches. Will an engine oil fed supercharger stress the oil more?
Old Jul 10, 2011 | 03:54 PM
Z06supercharged
Can someone get a oil temperature of a self contained one? I'm curious how hot it gets vs oil fed temp.
Old Jul 10, 2011 | 04:06 PM
kris6868's Avatar
kris6868
Is there a price difference between self contained an oil feed. I'm putting a down payment down Monday on a a&a kit an he told me for self contained was $200 more.
I know there is no difference..
Should I say anything?
An I hope I didn't hi-jack the thread...
Old Jul 10, 2011 | 07:58 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Depending on the manufacturer, the self contained can cost more. Specifically with the A&A Kit, the V2 Si-Trim to V3 Si-Trim upgrade is $150 and that price is set by A&A.
To Engine oil or self-contained
Old Jul 10, 2011 | 08:01 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I have dynoed the YSi and that headunit gets really hot on the dyno. The oil temps are in the 220 range and that transfers to the headunit. The IAT's were reaching 170 degrees. When I dynoed my car in the same heat, my IAT's were in the 115 range. I am using the V3 Si-Trim on a LS3 Vette. The ambient temp was 100 degrees and will get some more data.
Old Jul 10, 2011 | 08:08 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
A YSI moves a ton more air and is going to be hotter.
Old Jul 10, 2011 | 08:12 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I have installed the V2 on a 1999 Corvette LS1 and the IATs were stable in the 11x's. At the time, I did not measure the headunit temps. The ambient temps were in the high 90's. Damn TX heat. Not sure how hot the V2 got and would be intertesting to take IR readings in the future.
