Supercharger build thread
Here is the parts list so far
A&A bracket and intercooler
Vortec V2 head unit
6 rib setup with 3.8 pully
innovators west 8" overdrive pully
60 lb. injectors
NGK TR6 plugs
ACT twin disk clutch T1S-G01
New GM throwout bearing master and slave
RPM torque tube couplers
Lingenfelter fuel pump
KB boost a pump
ECS alky kit
Comp cams cam bolt lock plate
autometer cobalt fuel and boost gauge
TPS Motorsports rotors
Hawk HPS pads
Mike the powdercoater calipers
As of now the plan is to complete the install myself and trailer the car up to http://www.raceprovenmotorsports.net/ for the dyno tune. Same place I got my baseline done in Jan. Came up with 322 hp and 338 tq with only B&B bullets. And here are some pics of what I have so far.
So there it is, let me know what you think. I suppose it should be a pretty stout setup. I want to make sure I have all the bases covered and don't end up missing some vital link in making this a reliable street setup.
Vortec V2 head unit
innovators west 8" overdrive pully60 lb. injectors
NGK TR6 plugs
KB boost a pump
ECS alky kit
Hawk HPS pads
As for the supercharger I got the front end all apart too. The cam bolts are locktited and held down with locking tabs. The IW crank is on and pinned. the pan is set up for the drain line. Due to going with the 8 rib crank I decided to just order an 8 rib conversion. why waist 2 ribs on a crank. so the PS pulley is on and appears aligned as best I can tell with the laser rig. Got my oil lines ran and put the rack back in.
Well thats about where I am at. at this point I can say I truly enjoy working on this car, for the most part everything is going smoothly. No big hang ups, having the torch came in handy on several occasions. My only gripe is the damn abs module blocking the PS pulley, but that is the price you pay for working on a corvette.
