Doing some tuning today, big thanks to tha B-Man for lending a fresh mind, mine is spent. I plugged in the data to the dyno program and came up with this. Its not gospel and there is much room for improvement on my tune, but I thought it was pretty neat.
low timing, no meth, heat soaked, 18psi, rich as fawk ( 9.0 ish afr's )
Yea that would be nice. Its damn near 100 deg here
I changed the baro to houston along with 100deg temp and my 220 driver weight, this it what it comes up with now. Would be nice if my car were near this.
I'd like to take a peek at the tune. Are you trying to line out a non-meth dependent tune? Must be no timing in it at all to be running 18# with no meth. You're leaving A LOT of power on the table with it that rich.
Glad I could help out man! It's the least I could do from where I'm sittin'. I hope you're not still running as rich as you were. I also hope your virtual dyno #'s are close. That would mean your car should be quite competitive against little P1SC charged bananas.
Just trying to get the tune close BEFORE I add the meth back in it. As it is currently, 9.0afr without meth. Looking for 11.3ish with meth when its done.
As I said, its only a program, not an actual dyno.
