Fast intake map sensor and FI
Old Jul 13, 2011 | 02:48 AM
reactor2's Avatar
reactor2
Default Fast intake map sensor and FI
For those of you running a Fast intake and FI how did you secure the map sensor? If I recall correctly the Fast intake has no provisions for securing the map sensor (not that there is a lot of room). I'm sure any significant boost is going to pop that sucker right out of there.
How did you guys handle this?
Old Jul 13, 2011 | 04:11 AM
03redzo6's Avatar
03redzo6
i suspect i might have a leak back there since i pullied down and didn't move from 14psi
Old Jul 13, 2011 | 09:21 AM
reactor2's Avatar
reactor2
At 14 psi I have to believe that you popped that sucker right out of there. I can't believe Fast didnt provide any mechanism to secure the sensor. I suppose you could screw a barb fitting in there and relocated the sensor or just plug it and run the sensor off of another manifold vacuum source.
Old Jul 13, 2011 | 06:17 PM
reactor2's Avatar
reactor2
If I run vacuum off of the brake booster line and insert a brass plug into the map sensor whole on the manifold I should be ok right?
I read that someone popped the map sensor out of an LS6 manifold and those use a clip to hold it in so I have to believe that FAST owners have to do some type of mod with FI applications.
Old Jul 13, 2011 | 06:37 PM
ZO6ME's Avatar
ZO6ME
I blew mine out with a 4.0 pulley. I just made a metal bracket and screwed into the intake. I also installed an iat sensor into the back of the fast with a millimeter to spare.
Old Jul 15, 2011 | 01:05 AM
03redzo6's Avatar
03redzo6
i wonder if relocating the map sensor to the vacuum block i have would work and not affect the performance of it
Old Jul 15, 2011 | 09:32 AM
bullitt4110's Avatar
bullitt4110
yes you can. Ive also in the past tee'd into the A/C vacuum line (the one that plug into the passenger side on the back of the intake). Any good vacuum source will work for the map.
Old Jul 15, 2011 | 11:47 AM
JMBLOWNWS6's Avatar
JMBLOWNWS6
This is how we do them now. Works great and easy to get to the map for a 3 bar upgrade
Old Jul 15, 2011 | 11:31 PM
reactor2's Avatar
reactor2
What are you using to seal the map sensor hole on the intake?
Old Jul 18, 2011 | 02:38 PM
03redzo6's Avatar
03redzo6
im thinking of using jb weld but i would like to know if there is a easier way to do it using something else
Old Jul 19, 2011 | 10:23 PM
wheelybar1's Avatar
wheelybar1
Use a 2-part epoxy.....I filled the hole up in the front of the intake & drilled it after it cured. 3M Automix 8115, can even be tapped if you leave enough meat.
To Fast intake map sensor and FI
