Valve Springs ??????
Old Aug 6, 2011 | 10:00 PM
easyvette's Avatar
easyvette
Default Valve Springs ??????
Ok took the car today had it up on rollers. Car put down a decent number all things considered. But my power curve stopped somewhere around 5200rpm and basically went flat... I am leaning torwards valve float?
The cam is just under .600 running the AFR 225 small bore heads. I would like to do spring swap as these spring have 20K street miles on them. Be nice to get a good idea of a spring to recomend. Heard of some of the patriot springs failing so really dont want to go there. I would rather spend a little bit more money and get something a wee bit better.
Old Aug 6, 2011 | 10:34 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
Where is the dyno graph? How large is your motor & which power adder are you running?
Old Aug 6, 2011 | 10:53 PM
easyvette's Avatar
easyvette
[IMG][/IMG]
crappy phone pic but you get the idea... Current springs have quite a few passes on them and about 20K street miles... Just looking at the little magic wave at the 55k mark making me think valve float...
Old Aug 6, 2011 | 11:10 PM
jobberone's Avatar
jobberone
jobberone
can't see the dyno. We need to know your setup. You could be falling off due to backpressure. Post as much as you can including your cam specs, exhaust and type intercooler.
Old Aug 6, 2011 | 11:48 PM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
Exactly what I was getting at. Street miles don't mean crap.
Old Aug 6, 2011 | 11:50 PM
robert miller's Avatar
robert miller
Default ttt
Good power until about 5300 then it is as if he let off of it. more about the set up and parts in her.
Old Aug 6, 2011 | 11:51 PM
Its Bruce's Avatar
Its Bruce
Engine size, s/c type, pulley size, cam specs, exhaust specs, peak boost?
Old Aug 6, 2011 | 11:58 PM
easyvette's Avatar
easyvette
Build is pretty basic under the hood...
Procharger D-1 (flip drive 8rib)
383 cubic in
AFR 225 heads
American racing 1-7/8 no cats.
cam 226 232...
Going on a massive boost leak hunt in the morining
Old Aug 7, 2011 | 11:57 AM
easyvette's Avatar
easyvette
Back playing again this morining. Testing for boost leaks. Was getting alot of air out of the bypass valve. So pulled the bypass (vortech mini race bypass) plugged that off and started testing again. All the piping held pressure up to 30/35psi and then my temp plug let go. What a dam bang that had!!!! At 25 psi the piping was solid!!!
So is the bypass junk now?
Old Aug 7, 2011 | 01:37 PM
Warp Factor's Avatar
Warp Factor
When you pressure tested, did the manifold have pressure? If you blocked off in front of the manifold, the vacuum/pressure port on the bypass valve wouldn't have had a signal, which it needs to work properly.
Old Aug 7, 2011 | 02:24 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
What's the pulley combo?
The D1 might be out of air-there is only so much air it can move.
Old Aug 7, 2011 | 03:23 PM
JLayer's Avatar
JLayer
For what it's worth, that's graph is exactly what mine looked like before I swapped springs b/c of valve float. Mine died off around the 5200-5300 range just like yours. Search for my name and you'll see my graph. I made another thread with the end results afterwards.
Old Aug 7, 2011 | 04:10 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It's the bypass valve. It's the easiest part to replace. Replace it and head back to the dyno. You'll see what you're looking for.
The springs might be a contributing factor, but you're losing more boost than you might think out of that POS Vortech bypass valve.
Replace it and just look at how much boost you pick up. That will give you an indication of whether or not you can expect to do better on the dyno.
Old Aug 7, 2011 | 08:12 PM
easyvette's Avatar
easyvette
Have a Big Mondo valve here on the shelf so thats the first plan of attack... Just trying to figure out where the hell to put this beast of a valve.
As for when I tested it. I took the entire intake out of the loop. The rockers are still on in the car figured the air could have found an open valve. So capped of the intake coupler with a plug also. Basically in the end had the charge pipe from the supercharger plugged and the intake charge pipe plugged and the bypass valve plugged becasue the bypass was leaking alot of air. Going to get this new bypass valve on and test again to see how much air comes out if any compared to the last test. From there its gonna be borrow a big red procharger valve for test purposes.
Arun as for spinning yep I am overspinning the heck out of it... I was about 3K over max impeller and spoke to a tech off the record and he said I should be fine. That was with the 3.4 and the inovators west damper. I do plan on spinning this thing until it totally runs out of steam. I dont think its out of steam being about 3K over its not the most effiecent thats for sure.
Old Aug 8, 2011 | 07:22 AM
Warp Factor
Since the intake manifold is blocked off, I think you will also need to apply pressure to the small hose going to the bypass valve to know if the valve is leaking under actual boost conditions.
Old Aug 8, 2011 | 05:34 PM
easyvette's Avatar
easyvette
Good call... Never thought about that one when I took the intake out of the loop... Already cut the little bypass flange off so its going to be the big guy regardless. The bigger vale has a much bigger chamber on top of the hat for a better hold back ratio... But I will remember that when I retest this valve on the flange before it goes in the car.
To Valve Springs ??????
