Altenator pulley issues
Old Aug 8, 2011 | 04:08 PM
JSTAN's Avatar
JSTAN
Default Altenator pulley issues
Wondering if any has encountered this problem and if so a solution.
I have an 02 Z06 with a Magnacharger. 3.0 pulley size, pulling 9 lbs boost.
I do HPDE's and have had problems breaking the altenator pulley off the shaft.
So far I have spun 3 pulleys off the shaft this year.
These are aftermarket altenators from Autozone, (lifetime warranty).
Anyways, just wondering if others have encountered this issue and if so, what did you do to fix.
Old Aug 8, 2011 | 05:08 PM
HP_Addict's Avatar
HP_Addict
the pulleys are prone to loosening. Be sure to apply some red locktite and torque it down real good.
Old Aug 9, 2011 | 01:32 PM
robert miller's Avatar
robert miller
I had to do the same 2 diff times, until I put locktite on it also since that thing is on there...Robert
Old Aug 10, 2011 | 12:09 AM
Blown_2001Z06's Avatar
Blown_2001Z06
Cartek Flip Drive or Dallas Performance Direct drive. Gotta think it is putting the same stress on everything else. You will probably also get a little performance increase.
Old Aug 10, 2011 | 09:16 AM
HP_Addict's Avatar
HP_Addict
the Cartek unit is a great piece, but overkill in this situation IMO. Plenty of people running a maggie without problems. Now if he were bending the alternator shaft that would indicate too much stress. But a pulley working loose is fairly common on supercharger applications and an easy fix with locktite.
Old Aug 11, 2011 | 09:15 AM
JSTAN's Avatar
JSTAN
Thanks for the info guys.
I will try the red loctite and keep my fingers crossed.
Old Aug 11, 2011 | 11:01 PM
robert miller
Mine has not giving me any more problems at all. This will work for you man....
To Altenator pulley issues
