Methonol siphoning into intake?
Old Aug 11, 2011 | 11:46 AM
flash of red's Avatar
flash of red
Default Methonol siphoning into intake?
I have a Alky Control system fro ECS/ Julio. I am suddenly having trouble with a flooded condition upon start after my car has sat over night etc. I just fixed my alky reservior allowing it to hold a full tank. The hard starts started after this tank was fixed. The car had some white smoke come out the tail pipe when it started. All this to ask, are there issues with siphoning? The car runs great once it gets started. My alky line dips down low before it ascends upward toward the air bridge which should discourage siphoning.
Old Aug 11, 2011 | 11:52 AM
396375's Avatar
396375
St. Jude Donor '08-'09
I don't think anything can siphon through a pump.You could disconnect the line from the nozzle and see if it drains into a can.Call Julio.
Old Aug 11, 2011 | 12:00 PM
Mike04's Avatar
Mike04
You should have a check valve in the line attached to the filter (could be stuck open a little). Also, Julio sells small check valves that go at the nozzles. Give him a call and he will help you through your issue
Old Aug 11, 2011 | 12:13 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The pump will free flow without the check valve, so check that first. Some of the original kits did not have the check valve, so look for it first. It is part of the filter assy and has an arrow on it.
Old Aug 11, 2011 | 01:34 PM
flash of red
Ok I will check for it. The kit is about 7 years old, but has Julio's newest pump upgrade.
Old Aug 11, 2011 | 02:31 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Only part of the filter assembly when it's a dual nozzle system. The single nozzle systems have a check valve just behind the nozzle at the pipe. I would recommend you remove the pipe and let it hang lower than the tank. Drooping hoses won't stop siphoning if the check valve has failed. Only having the jet higher than the top of the methanol level will. If you let that pipe hang over night and put something to catch or guide it to a pan underneath, you'll get your answer.
Old Aug 11, 2011 | 03:12 PM
flash of red
I ordered a check valve from Julio. My kit is an older one before they started using the check valve.My line goes directly into the elbow that contains the spray nozzle.
Old Aug 12, 2011 | 02:13 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
I think I am also having this problem. Somehow I am going through an entire washer tank of meth in one drive of the car.
Old Aug 12, 2011 | 02:23 PM
Mike04's Avatar
Mike04
You must really be in boost a lot to use that much
Old Aug 13, 2011 | 03:13 PM
Z06PSI's Avatar
Z06PSI
Who me? LOL. The PD is almost always in boost.
To Methonol siphoning into intake?
